Throttle body - Tee, T/B - Inlet & water Pipe Gaskets. *M12+14 Wheel studs*
Started by randombadger69, April 30, 2012, 12:57:34 AM
gaz g40
Can i order the inlet to throttle body gasket for 51mm also regarding them wheel bolts do you supply the nuts aswell? And would i still be able to run my locking wheel nuts if i ordered only 12? Cheers
randombadger69
Hi Gaz,
I can supply the gasket you require, I have this in stock.
Regarding the studs I can supply these individually at £3.75 or £45 for 12. I do not supply nuts for these. I have used auto imparts in Leighton buzzard for these in the past. They will supply taper or radius seat with a 19mm hex.
As regards to mix and matching I am no expert but the only consideration I can think of is the weight difference of one locking bolt verses a stud and nut affecting balance?
gaz g40
Do you accept paypal. Ill take two tb to inlet 51mm gaskets and two water pipe gaskets aswell please mate. Ye i understand what you mean with the balancing. If i was to buy a set of bolts would you sort me nuts out and ill pay extra?
Thanks gaz
randombadger69
I can accept payment with PayPal as long as the 4% surcharge is covered. I can supply the inlet gaskets, however I believe the water pipe gaskets are out of stock.
As regards the wheel nuts I could arrange to supply these, although will cost more due to additional postage costs.
Do you require taper or radius seat?
gaz g40
How long till the water pipe ones are in stock? Il check when i get home as the wheels are bbs rms which i havent used yet cheers
randombadger69
Can't say on the gasket availability. The guy that was cutting them for me has gone travelling for sometime. I need to see about an alternate supplier.
