Throttle body - Tee, T/B - Inlet & water Pipe Gaskets. *M12+14 Wheel studs*
Started by randombadger69, April 30, 2012, 12:57:34 AM
randombadger69
Yeah asked for the paper type not the rubber o ring as fitted on the 3F etc. I got one when I fitted my GF engine into my mk1 golf. a year later same part was not available. this was through an independant motor factors mind. Dealing with TPS I should imagine.
They've never got it wrong before though!
Im going to have to get a 51mm T/b off justin when I have some free dolla. See what you mean Re: fitting then. May be able to improve things on the gasket front.
Agent47
paulpolo
I'll take a water pipe gasket, a throttle body to inlet gasket and a throttle body to elbow gasket if you have any left.
randombadger69
Pm's sent to both the above.
Now have 51mm and 47mm in stock a plenty.
Freddy77
Hi can I get a throttle to elbow gasket, standard size and a throttle body to manifold gasket too please if you still have some available,
Fred
randombadger69
Hi Fred,
Both in stock. I will pm you payment details.
Regards
vee-dub90
randombadger69
randombadger69
Currently out of stock of t/b to inlet gaskets. all others a plenty.
gaz g40
any news on the throttle body to inlet gaskets al take two mate cheers
randombadger69
Right, I thought it about time I updated this thread with the gaskets I can offer for your OEM+ G40 induction applications.
First up is inlet to Throttle body gasket for a 3F (GT) inlet manifold. Looks like this on the 3F manifold.
Second option is what i believe to be a standard PY (G40) Inlet to Throttle body gasket. Looks like this on the 3F inlet manifold.
And lastly is what pete was mentioning regarding resticting flow. The inside diameter (ID) of the standard G40 Inlet to Throttle body gasket measures circa 48.5mm. Which means it will actually restrict flow if you are fitting a 51mm throttle body to the inlet. Not only this, but the inlet manifold itself will also need porting work. To allow for this I have had some gaskets cut from the standard PY pattern but "notched" to allow clearance for the larger ID of the 51mm Throttle body. This gasket will also act as a template for any porting work. I only have an illustration of this fitted to a 3F inlet manifold.
So you can see how much material needs removing to make the most of an oversize 51mm Throttle Body when fitted to a 3F inlet manifold.
I will update the original post in this thread in due course. These are all in stock aplenty.
randombadger69
Bump. I can now offer high quality direct fit M12 and M14 wheel studs for 4 and 5 stud VAG vehicles.
Etches
Am I right in thinking those studs are £4.75 each e.g. £76 for all corners?
randombadger69
Correct. £4.75 per stud, so £76 for a set of 16. I have amended the post to clarify.
randombadger69
I have now amended the price of the wheel studs. Can offer these at a reduced rate. see top of thread for details.
