oil cooler pics
Started by Jake G 4 0, July 13, 2010, 04:35:49 PM
Jake G 4 0
I was thinking of investing in an oil cooler kit,  i was just wondering where you would mount it if you had a standard or uprated intercooler.  If you could post some pics i would be very gratefull.
Jake
lance
hard to see it but its on the right lookin at the photo, one on the left is another radiator.
g40Ross
Quote from: lance on July 13, 2010, 08:06:29 PM
i like the look of the fmi!! is that a custom job? or from another car?
Ross
lance
escort cosworth mate, got a charge cooler built into it too ;)
Alex
Mine's tucked in between the radiator and the bumper iron. You can see it just below the number plate here:
vwmk3jon
mines sat up behind where the passenger side fog light would be.
Jake G 4 0
Did anyone buy their own heat exchanger and do their own work or did you all buy a kit??
If you did It yourself how did you go about it??
Thanks for the advice and pics
I bought my own heat exchanger, thermostatic sandwich plate and got the pipework made up at a hydraulic pipe place in Rochdale.
Then for mounting the heat exchanger, got the welder out and made some brackets.
lance
i done the same as haysey too. i used a vauxhall thermo plate though, free off a friend, there on red tops and let turbo's. think they are on some early 2.0 8v's too
GAF2
when mounting the cooler behind the passengers fog light, did you have to cut holes for the pipes or can the be routed to the sandwhich plate without cutting etc.
lance
no you dont need to cut anything mate, there is a gap behind the headlight and then bellow the chassis leg
GAF2
sweet mate, will be fitting my kit nxt week once i get sum bracketts sorted
Jake G 4 0
How much money did you boys save by make shifting your own kit??
the only thing I had to cut was the bumper iron, I'm trying to find a pic I know I've got somewhere but can't at the moment.  You can kind of see it in these pics though:
lance
mine cost me 23 quid all in, way cheaper than 100 pound plus!
haysey them comps look class!
