right guys, this thread has got me into gear to fit my kit (had it nearly a year) but went to look at my sandwhich plate and am not sure if its right, it is thermostatic controlled but to me it looks like the thermostat is in the open postion. see pic below.http://i364.photobucket.com/albums/oo82/GAF2_photo/oil%20cooler/SDC10508.jpg
also does it matter which pipe you put on to which outlet, i was thinking no because it doesnt matter which way the oil runs through the cooler?
i imagine the side of the sandwhich plate with the rubber seal on goes against the block because the filter already has a seal on it?http://i364.photobucket.com/albums/oo82/GAF2_photo/oil%20cooler/SDC10509.jpg
one last question and might be a bit stupid, with a kit fitted do you need to increase the amount oil you put in the engine or do you just continue to fill to the level on the dipstickcheers guys
