Right box is out of the car, at a quick look there is masses of play in the drive flange in and out as well as rotational play, cant see this being normal
when i turn the drive flange with it in gear its rather noisy, sounds like a stray bearing, but could be wrong, could just be normal
now im about to strip the gearbox down as per your brilliantly put together guide, but ive just realised you only replace the diff bearings. I cant find that haynes manual you speak off. Are the other bearings straight forward to change? Have you ever done them? I havnt ordered any bearings as of yet, want to get the box apart first
appreciate your help mate
