Technical => Chassis & Braking => Topic started by: z3i on June 24, 2013, 02:47:38 pm
Well i need my box rebuilt, and looked through a few guides on here and think i could do it :)
i found a rebuilt kit for the 085 boxes and all the seals and bearings came to £120 ish which is pretty cheap!
im still unsure if i want a diff or not as its alot of money, hopefully i can get one off here for decent price
my question is i have loads of play in the gearstick like you know if its neutral you can push it left and right and it returns to the centre? Mine doesnt, it has resistance one side but not the other, its just floppy like stiring soup
ive changed all the linkeages and still does it, someone told me its a part inside the box
could someone enlighten me? I cant find any rebuild parts for the selector rod, what is actually going on in there? Has anyone had that bit apart?
many thanks taylor
I don't know much, but I had my gearbox rebuilt and the left/right movement on gear stick in neutral got its springness back.
I understand there are return springs inside the gearbox, that a good rebuilders will/should replace...
if thats the case i may get someone to do mine, where did you get it done?
I'm down in Devon, if you want details pm me, but TBH I would just go with a local gearbox rebuilder who is respected locally. That is what I did. Its only a polo gearbox after all, you just want an honest company who will replace ALL the bearings seals etc.
Be prepared to pay at least £300 and possibly/probably more...
yes the springs are inside the gearbox that make the stick return to center.
If all you want to do is to replace the bearings, seals and those springs then it's not hard to do it yourself. It's if you want to start stripping down the shafts to replace actual gears or synchros that it really requires tools you aren't likely to have and some experience.
I did an FAQ guide to doing the diff bearings, it's not especially hard. To do the gear shaft bearings you'll need to remove 5th gear and then pull out the shift mechanism and the gear shafts. It's certainly DIY'able (I've done it for example). Just take care to note how everything fits together (particularly the shift fingers as they are a bit like a 3D jigsaw).
When you open the box up you'll see the springs that make the gear stick return to centre, easy to replace.
If you are buying bearings from somewhere other than VW, be careful that you are buying quality parts as cheap bearings can be awful quality and wont last (watch out for chinese-made knock off ones too, don't buy them off ebay :) )
thanks for that, i was gonna buy ebay ones, but will go to vw now
and yeah just read your guide, looks spot on! Though i dont understand all this setting up the end float
i got quoted today £500 from a local place to replace the bearings and seals, seems dam expensive!!!
Is it any harder to do than rebuilding a supercharger as ive done that :D
thanks for that info on the springs for the selector shaft mate :) cheers
yeah, don't buy bearings from ebay.
VW will be expensive, give GSF or Euro Car Parts a try, just look for decent make ones like FAG or SKF etc...
Getting the preload set correctly is pretty important so give it another read till you understand it.
Haynes do (or did at least, not sure if it's still in print) a gearbox rebuild manual which has a section on the VW 084 gearbox which is the 4-speed version. It's very useful. It'd be worth getting your hands on that if you can.
Ok mate, thanks for the advice, still debating whether to do it myself, really dont want to brake it
This will probably fix the play in the gear selector.
http://www.polog40.co.uk/forum/index.php?topic=5428.0
and these are what u probably need to replace
thanks for the help, but its inside the gearbox as hayesey says, the little spring bits, ive replaced both those parts you have posted
You're very unlikely to break anything. I'd just give it a go. At very least you could crack it open and replace those springs.
ok lol, ill give it a go, you may get an inbox full of messages if i get stuck haha
thanks for your help mate :) hopefully getting the box off this weekend
Was looking around and found this, what do you think?
http://www.ebay.co.uk/itm/171015208053?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2648
phoned gsf and they wont give me trade discount anymore as we dont order enough stuff, skf bearings are bang on, what about the other ones?
that seems dam cheap :D
thanks in advance
I would just avoid ebay at all costs for these things. There's a chance that what you get wont be the same brands as the picture. Then there's another chance that they will look like decent brands but actually be counterfeit. Ebay is full of counterfeit parts, there's also a lot of counterfeit computer parts, flash memory drives etc,.. on there. Same goes for Amazon.
If it seems to cheap to be true, it wont be true!
having said that, that auction does look pretty legitimate. Perhaps phone them up since they give a phone number and see what they say about what brand you'll get.
Right box is out of the car, at a quick look there is masses of play in the drive flange in and out as well as rotational play, cant see this being normal
when i turn the drive flange with it in gear its rather noisy, sounds like a stray bearing, but could be wrong, could just be normal
now im about to strip the gearbox down as per your brilliantly put together guide, but ive just realised you only replace the diff bearings. I cant find that haynes manual you speak off. Are the other bearings straight forward to change? Have you ever done them? I havnt ordered any bearings as of yet, want to get the box apart first
appreciate your help mate
Ah i found a copy of it on here, you photocopied it, i downloaded it as a pdf, seems to work :) the edges are a bit blury lol, but should do the trick. Thanks for putting that on the forum mate
If your going to start pulling gears off don't use a cheap gear puller get a very very good one and be super careful.
I broke a gear tooth in my gt box without much force using a puller
thanks for the advice mate :)
i think im just gonna change the diff and driveshaft seals, too worried about wrecking something. Oh and set the preload as i think its wrong as theres in and out play in the driveshaft flange
where did you get your decent press from? Any recommendations?
thanks
hmm, it seems to be out of print now that book, there are some for sale on amazon for like £35+.
if there's play in the flanges have you checked the tightness of the central allen head bolt in them?
http://static.photobucket.com/player.swf?file=http://vid1243.photobucket.com/albums/gg547/organika2/MOV_0427_zpsd4a886fc.mp4
got it apart, it would apear the diff itself is worn itself, bearngs dont seem too bad (know they are clearance bearings)
would you mind watching this video just to confirm it is fudged as the senior bmw tech said its knackered but they dont rebuild gearboxes
so pauls word would be good, let me know if the link doesnt work
i can only imagine that by the time this wear is transmitted to the wheel its a massive amount
what should i do? New diffs dont come with the inner cogs do they?
much appreciated
Would a quaife sort your problems out?
I dont know as i dont think it comes with the bits that are worn on mine. In pauls guide he changes the old sun gears over to his new diff
(http://static.photobucket.com/player.swf?file=http://vid1243.photobucket.com/albums/gg547/organika2/MOV_0427_zpsd4a886fc.mp4)
any better
<a href=http://s1243.photobucket.com/albums/gg547/organika2/?action=view¤t=MOV_0427_zpsd4a886fc.mp4 target=_blank><img src=http://static.photobucket.com/player.swf?file=http://vid1243.photobucket.com/albums/gg547/organika2/MOV_0427_zpsd4a886fc.mp4 border=0 alt=></a>
Not that hard mate ill give you a hand if u need it? And ur floppy gear stick is deffo down to the return springs in the box!
Thanks mate :) ive got it all apart, check the video. yeah i can see the return spring, one looks stuck, but im too scared to touch it though
think the diff is shagged :(
if you could give me a hand i would much appreciate it mate, will sort you out some, beers, monies or g parts? haha. you much experience on boxes? or just want some experience before you fit your diff?
im not sure what to do, cant afford a diff atm, but need the box back in asap
give me a text yo :D
I've got a spare VW diff in the garage. Will check condition tomorrow if I get time.
that would be bang on :D have you seen the video of mine, can you just confirm it is shagged?
would i need to change the bearings and set the preload on yours?
How much you looking for? Cheers andy
I've had some experience from work haven't opened up a polo box befor tho but I'm refurbish mine myself and putting my lsd in ;) u should save up man they look the nuts!!!
