Helloooo!
For those who don't know, I have a Mk1 Golf with a G40 Engine fitted, it also has a T25 Garret with a GT cam and the 6 psi boost switch mod.
The engine has ran sweet as a nut since I finished building it in November last year, my only gripe was max boost was 0.5 psi but I was never too fussed about it until I had replaced my fuel pumps.
I did some welding on the car a couple of months back, and had disconnected the battery while doing so, to avoid shorting any of the electrics, however ever since then I have been having running issues.
Basically, you would be driving along and start accelerating, the car would bog down like hitting a brick wall, with any amount of throttle pressure and this is only rectified by lifting my foot entirely off the throttle and then back on and it would go like shit off a shovel.
It's beginning to get more and more frustrating in daily driving and is taking its toll on already tired engine mounts with the constant accelerate, lift off, accelerate.
In my quest to solve it, ive done the following
New Inline Fuel Pump
New In Tank Fuel Pump
New Fuel Pump Relay
Cleaned Spark Plugs and set gap to 0.7mm (Tried both W5DP0's and NGK BP7EVX)
New Rotor Arm
New Dizzy Cap
New Spark Leads
Known working coil
New Coil
New Blue Temp Sender
Known working lambda
New Lambda
Replaced all engine earths and cleaned mounting points
Replaced all vacuum hoses
Of which have the following setup
2 brake servo take offs, one directly to FPR, one directly to ECU - ECU one is 470mm
Bottom of inlet manifold take-off has the following connected - dump valve, actuator, 6 psi boost switch and boost guage
Set the static timing using a screwdriver to note TDC and marked up the crank pulley and casing
Set timing to 6 deg at 2k rpm in service mode (was set to 10 deg)
Set CO to 0.7% in service mode using a gas analyser
Changed the actuator - which has finally given me a bar of boost (gave me 2 bar with a bleed valve - standalone from the rest of the vac system, plumbed into the main system now to avoid dangerous boost spikes)
Upgraded the coil to a 8v digifant GTI coil and amp
The CO will now only go down to 4.3% in service mode for some reason, and no amount of tweaking the CO changes it, this happened to my last CO pot, so replaced for another and its done it again)
The engine is running very rich, pretty much shows rich on the narrowband AFM all the time, apart when its bogging down, where when warm it reads in the middle)
Today when I was performing the 8v coil mod, I decided to check the ECU pinout to trace the black/green wire and noticed that inside the ecu connector plug was a load of water and some green furry connections! Its a wonder the car ever ran at all, So i stripped the ECU down, no water inside thankfully, and cleaned up all the connections and put it back together.
Driven home tonight and still got the same behaviour - driving along, car starts bogging down under any acceleration, lift off the throttle and back on it again and the car is happy again. also possibly worth noting that if you try and drive off with very light throttle the engine will try and cut out, so a bit more throttle and its sweet. It also backfires and pops on overrun. starts up and idles fine until warm where it occasioanly wants to drop the idle and sometimes cut out.
At the end of my wits now and have considered swapping it all out for my mapped G-lader setup, but it involves making a custom drivers mount, which I plain cant be arsed as I dont have a spare engine, so it would be an all or nothing affair.
Has anyone else experienced issues like this?
Things I have left to consider
Fit my wideband lambda - VEMS with datalogging - got my boss just need to fit an appropriate holesaw to drill out a hole in the exhaust, or take it to an exhaust place to do on the ramp
Check resistance and connectivity between the ecu pins and relevant sensors/ground
Check Pressure Switch calibration and wiring
Replacement MAP sensor
Replacement ECU
Put the G-lader stuff on
Help mehhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh!
