Author Topic: Uprated clutch cables  (Read 1230 times)
Offline Alex
  • Hack
« on: August 19, 2012, 02:31:19 pm »
Can you get these?
I've got a fairly heavy clutch, I'm concerned about snapping cables. Does anywhere make them with stronger wire?
Re: Uprated clutch cables
« Reply #1 on: August 19, 2012, 02:38:19 pm »
carry a spare i n the boot and some string and 2x10mm spanners and they can be changed in about 10 mins
Offline scotsjohn
« Reply #2 on: August 19, 2012, 04:20:41 pm »
Try Practical Classics Alex; IIRC there should be a couple of adverts in there.
Offline Vwpologt
« Reply #3 on: August 22, 2012, 08:57:17 pm »
Mine was going the same I found a crack in the peddle box so wen u press the clutch the peddle box was moveing too. It be worth checking urs .
« Reply #4 on: August 24, 2012, 08:47:25 pm »
What clutch have you got Alex? Check there's a bit of grease on the clutch arm too, they sometimes bind on the box housing
I keep my cable lubed (silicone is good and doesn't run out too quickly) as Pete says just carry a spare and a few 10mm spanners.
My pedal box is hanging in there, will strip it out in winter and weld it up.
Offline Jezza-7
« Reply #5 on: August 24, 2012, 09:57:59 pm »
Could get a hydraulic clutch? Only problem is mounting a master cylinder for the clutch.
