Author Topic: PSD Eaton kit...tensioners etc. Why?  (Read 3594 times)
Offline AlexG40
« on: July 18, 2012, 06:29:34 pm »
Anyone know why the PSD eaton kit uses a tensioner pulley and further tensioner on the toothed belt?  As far as I can see if they weren't there the belt would be exactly the same as the standard PSD G-lader toothed belt kit.  Why has it been complicated?  I assume there is a reason but I can't see what it is.
Re: PSD Eaton kit...tensioners etc. Why?
« Reply #1 on: July 18, 2012, 07:14:26 pm »
longer belt? inability to pivot properly to tension charger?
Offline AlexG40
« Reply #2 on: July 18, 2012, 07:35:33 pm »
Yeh, it has a longer belt, but I would have thought the easier solution was a shorter belt. The charger tensions the same way as a G-Lader although it's pretty much at full extension, but again, a shorter belt would have done the trick.
In the absence of a better idea though....
« Reply #3 on: July 19, 2012, 03:41:00 pm »
You got a pic? Has the ensioner got a guide on it too?
Offline AlexG40
« Reply #4 on: July 19, 2012, 06:30:46 pm »
Here we go.
« Reply #5 on: July 19, 2012, 07:39:56 pm »
it may be that the 'smaller' belt only available is 16mm or something so too small - hence tensioners
Offline youngprodigys
  • G 3URO
« Reply #6 on: July 21, 2012, 12:27:23 pm »
The top tensioner isnt a tensioner as such, it shouldnt touch the belt when its running- steve told me that its there to stop belt slap and it will want to move about and its there to stop it skipping teeth and knackering the belt, the bottom one is for tensioning it!
  • G 3URO
« Reply #7 on: July 21, 2012, 12:28:21 pm »
the original tensioner position is a bit rubbish aswell - hence why on your kit there is another!
Offline AlexG40
« Reply #8 on: July 21, 2012, 04:26:19 pm »
I see. Makes some sense I suppose. The eaton pulley is a bit further than the G lader one I suppose too.
