Author Topic: G40 Adjustable TCA  (Read 17946 times)
  • Validating Members
G40 Adjustable TCA
« on: March 28, 2012, 01:07:46 pm »
All,
We’re now in a position to start gathering numbers for our first batch of adjustable track control arms. These are primarily designed for track use in addition to a stage 3 subframe. This then allows camber and castor adjustment.
The exact camber adjustment will depend entirely on top mount used and current castor angle, I run -3.5° on my car (PPP top mounts), Andy runs -1° on his (standard top mounts) which was corrected from +0.6°
The TCA is adjustable on vehicle, and is secured with two locking nuts (similar to the compression strut on a Stage 3 Subframe), it is supplied with a standard rubber OEM bush- we highly recommend a nylon replacement (which we can supply separately).
As usual the rose joint is a standard off the shelf item, with a rubber boot- all replacement parts found at Rally Design, Demon Tweeks etc, so no expensive repairs- I’m trying to find a supplier for ball joints currently to give a 100% serviceable arm.
Price is circa £200 + postage, dependant on the discount we can get for bulk buy of stock parts.
Please only put your name down if you have cash- and can wait ~8 weeks from point of order for delivery.
Many Thanks,
e-mail: enquiries@poloperformanceparts.co.uk
Re: G40 Adjustable TCA
« Reply #1 on: March 28, 2012, 01:09:04 pm »
As fitted to my car- please note the chassis TCA mount/ Subframe mount is enlarged to 13mm to accomodate a stronger bolt for the rose joint.
Offline dub-disaster
« Reply #2 on: March 28, 2012, 03:34:10 pm »
Ill take a pair of these Yoof been waiting for these for a while ;D ill take a pair of the nylon bushes aswell please got cash waiting give me a shout when you want payment
Offline Jezza-7
« Reply #3 on: March 28, 2012, 05:02:33 pm »
I'll deffo have a set mate. With nylon bushes as well.
Offline Tav
« Reply #4 on: March 31, 2012, 05:57:42 pm »
I'm a definite.  I already have nylon bushes.  Soon the better, but I can wait the 8 weeks.
I'll be running these stock length, with the ARB, I just want the inner rose joint and it's circa same price for g-lader site items.
Offline Tav
« Reply #5 on: April 28, 2012, 08:48:23 pm »
Is there and chance of getting a set sooner? All my suspension stuff is here so I'm desperate to get it together?
« Reply #6 on: April 29, 2012, 12:08:04 am »
I've also got suspension off and  would love to get hold of these asap if possible got cash ready.
« Last Edit: April 29, 2012, 04:47:39 pm by dub-disaster »
« Reply #7 on: April 29, 2012, 01:42:51 pm »
I'll try mate, but we've got our Mk1 in for alot of work curently too, kind of self inflicted!
Am hoping to pick frames up bank holiday weekend so will have a chat then, and keep you updated.
Offline POLOMON
« Reply #8 on: September 10, 2012, 09:16:55 am »
Hi Pete,
 Any updates on these? looking at the design would they be useable with a stock ARB? I know its probably not the ''best'' setup but is it an option?
Offline Tav
« Reply #9 on: April 05, 2013, 07:02:10 pm »
Pete if you need more people to make this worth it, ie. 5 I'll easy buy a couple of sets and then sell them on.
« Reply #10 on: April 05, 2013, 09:28:28 pm »
We can do small runs of 3 sets - but these are for off-highway use only, just done a run of 3 for a few people.
Names:
Tav
Offline vee-dub90
    • Facebook
« Reply #11 on: April 13, 2013, 11:29:31 pm »
Ill take a set depending on price and would they work on a stage 2 subframe?
« Reply #12 on: April 14, 2013, 07:06:18 pm »
Price for a run of 3 is £225 + Postage (approx £15 to Mainland UK).
These will work with a stage 2 subframe, but you're limited by the amount of camber you can run as the ARB isn't adjustable!
Offline Tav
« Reply #13 on: April 14, 2013, 11:43:58 pm »
I'll be running mine with stage 2, I just want the big beefy joints and the ability to adjust in future.
Offline vee-dub90
    • Facebook
« Reply #14 on: April 15, 2013, 10:16:56 pm »
Pm'd
