G40 Adjustable TCA
Started by Yoof, March 28, 2012, 01:07:46 PM
All,
We're now in a position to start gathering numbers for our first batch of adjustable track control arms. These are primarily designed for track use in addition to a stage 3 subframe. This then allows camber and castor adjustment.
The exact camber adjustment will depend entirely on top mount used and current castor angle, I run -3.5° on my car (PPP top mounts), Andy runs -1° on his (standard top mounts) which was corrected from +0.6°
The TCA is adjustable on vehicle, and is secured with two locking nuts (similar to the compression strut on a Stage 3 Subframe), it is supplied with a standard rubber OEM bush- we highly recommend a nylon replacement (which we can supply separately).
As usual the rose joint is a standard off the shelf item, with a rubber boot- all replacement parts found at Rally Design, Demon Tweeks etc, so no expensive repairs- I'm trying to find a supplier for ball joints currently to give a 100% serviceable arm.
Price is circa £200 + postage, dependant on the discount we can get for bulk buy of stock parts.
Please only put your name down if you have cash- and can wait ~8 weeks from point of order for delivery.
Many Thanks,
e-mail: enquiries@poloperformanceparts.co.uk
As fitted to my car- please note the chassis TCA mount/ Subframe mount is enlarged to 13mm to accomodate a stronger bolt for the rose joint.
Ill take a pair of these Yoof been waiting for these for a while ;D ill take a pair of the nylon bushes aswell please got cash waiting give me a shout when you want payment
I'll deffo have a set mate. With nylon bushes as well.
Tav
I'm a definite.  I already have nylon bushes.  Soon the better, but I can wait the 8 weeks.
I'll be running these stock length, with the ARB, I just want the inner rose joint and it's circa same price for g-lader site items.
Tav
Is there and chance of getting a set sooner? All my suspension stuff is here so I'm desperate to get it together?
#6
I've also got suspension off and  would love to get hold of these asap if possible got cash ready.
I'll try mate, but we've got our Mk1 in for alot of work curently too, kind of self inflicted!
Am hoping to pick frames up bank holiday weekend so will have a chat then, and keep you updated.
POLOMON
Hi Pete,
Any updates on these? looking at the design would they be useable with a stock ARB? I know its probably not the ''best'' setup but is it an option?
Tav
Pete if you need more people to make this worth it, ie. 5 I'll easy buy a couple of sets and then sell them on.
We can do small runs of 3 sets - but these are for off-highway use only, just done a run of 3 for a few people.
Names:
Tav
vee-dub90
Ill take a set depending on price and would they work on a stage 2 subframe?
Price for a run of 3 is £225 + Postage (approx £15 to Mainland UK).
These will work with a stage 2 subframe, but you're limited by the amount of camber you can run as the ARB isn't adjustable!
Tav
I'll be running mine with stage 2, I just want the big beefy joints and the ability to adjust in future.
vee-dub90
