Club Sponsors => Polo Performance Parts => Topic started by: Yoof on March 28, 2012, 01:07:46 pm
Title: G40 Adjustable TCA
Post by: Yoof on March 28, 2012, 01:07:46 pm
All,
We’re now in a position to start gathering numbers for our first batch of adjustable track control arms. These are primarily designed for track use in addition to a stage 3 subframe. This then allows camber and castor adjustment.
The exact camber adjustment will depend entirely on top mount used and current castor angle, I run -3.5° on my car (PPP top mounts), Andy runs -1° on his (standard top mounts) which was corrected from +0.6°
The TCA is adjustable on vehicle, and is secured with two locking nuts (similar to the compression strut on a Stage 3 Subframe), it is supplied with a standard rubber OEM bush- we highly recommend a nylon replacement (which we can supply separately).
As usual the rose joint is a standard off the shelf item, with a rubber boot- all replacement parts found at Rally Design, Demon Tweeks etc, so no expensive repairs- I’m trying to find a supplier for ball joints currently to give a 100% serviceable arm.
Price is circa £200 + postage, dependant on the discount we can get for bulk buy of stock parts.
Please only put your name down if you have cash- and can wait ~8 weeks from point of order for delivery.
Many Thanks,
e-mail: enquiries@poloperformanceparts.co.uk
Title: Re: G40 Adjustable TCA
Post by: Yoof on March 28, 2012, 01:09:04 pm
(http://img.photobucket.com/albums/v251/Young_Un/Mk3%20Re-Build/DSC01976.jpg)
(http://img.photobucket.com/albums/v251/Young_Un/Mk3%20Re-Build/DSC01983.jpg)
As fitted to my car- please note the chassis TCA mount/ Subframe mount is enlarged to 13mm to accomodate a stronger bolt for the rose joint.
Post by: dub-disaster on March 28, 2012, 03:34:10 pm
Ill take a pair of these Yoof been waiting for these for a while ;D ill take a pair of the nylon bushes aswell please got cash waiting give me a shout when you want payment
Post by: Jezza-7 on March 28, 2012, 05:02:33 pm
I'll deffo have a set mate. With nylon bushes as well.
Post by: Tav on March 31, 2012, 05:57:42 pm
I'm a definite.  I already have nylon bushes.  Soon the better, but I can wait the 8 weeks.
I'll be running these stock length, with the ARB, I just want the inner rose joint and it's circa same price for g-lader site items.
Post by: Tav on April 28, 2012, 08:48:23 pm
Is there and chance of getting a set sooner? All my suspension stuff is here so I'm desperate to get it together?
Post by: dub-disaster on April 29, 2012, 12:08:04 am
I've also got suspension off and  would love to get hold of these asap if possible got cash ready.
Post by: Yoof on April 29, 2012, 01:42:51 pm
I'll try mate, but we've got our Mk1 in for alot of work curently too, kind of self inflicted!
Am hoping to pick frames up bank holiday weekend so will have a chat then, and keep you updated.
Post by: POLOMON on September 10, 2012, 09:16:55 am
Hi Pete,
 Any updates on these? looking at the design would they be useable with a stock ARB? I know its probably not the ''best'' setup but is it an option?
Post by: Tav on April 05, 2013, 07:02:10 pm
Pete if you need more people to make this worth it, ie. 5 I'll easy buy a couple of sets and then sell them on.
Post by: Yoof on April 05, 2013, 09:28:28 pm
We can do small runs of 3 sets - but these are for off-highway use only, just done a run of 3 for a few people.
Names:
Tav
Post by: vee-dub90 on April 13, 2013, 11:29:31 pm
Ill take a set depending on price and would they work on a stage 2 subframe?
Post by: Yoof on April 14, 2013, 07:06:18 pm
Price for a run of 3 is £225 + Postage (approx £15 to Mainland UK).
These will work with a stage 2 subframe, but you're limited by the amount of camber you can run as the ARB isn't adjustable!
Post by: Tav on April 14, 2013, 11:43:58 pm
I'll be running mine with stage 2, I just want the big beefy joints and the ability to adjust in future.
Post by: vee-dub90 on April 15, 2013, 10:16:56 pm
Pm'd
Post by: Yoof on May 26, 2015, 04:44:08 pm
3 sets currently in stock.
Post by: 642855659 on November 11, 2015, 09:47:20 pm
Hi, can you give me an up to date price & picture ,and can you tell me if they will replace a standard TCA.
