As i said via Email, The s-tech chip runs fine with the 250's in (Rich obviously) but nothing like when your chip is installed.
You had the engine info, And the only thing i see different was the turbo, which will only effect fueling etc on boost ? It would barely idle never mind boost.
You also knew the situation with the camshaft, I told you i didnt know what cam it was, It isnt marked. I can only relay information that was told to me, As i said via email, Im not in a financial situation to change the camshaft at the moment, Especialy just to rule it out as a factor of why a chip wont work.
And Dyno operator tinkering ? He didnt touch the map at all, All he done was run the car on the rollers, check ignition timing and ajust AFR. The FPR was removed, ignition timing was at stock. You making it sound like your in this holy light and im a little elf who doesnt have a clue, Granted i know less than yourself, but no need to dumb people down to the rest of the forum to make yourself look superior. I understand you have a reputation to keep, having a buisness and all, but theres no need?
Also, As stated you didnt specify that it needed specific 250cc injectors ? Why only bring this up now ?
I will be at the garage tomorow after work, Ill grab a few photos of the camshaft.
