Yeh ill email both, Its booked in again for thurs evening.
Ignition timing is at stock spec yes,
It seems to run fine, But as the car has no tax or it isnt insured i cant test untill i get it back to the rolling road.
Your chip will idle lumpy but as soon as throttle is applied it cuts out.
No way of checking AFR unfortunatly.
The altanator is working fine but ill check voltage after work.
Ill also check CO pot. What roughly should it be reading ? will it be in ohms, k, meg?
Which pins are the idle and WOT switch ? And do i just check resistance between the two ?
And as previously stated the camshaft is aftermarket but it isnt stamped, Iv had it out a few times now to have a look. Iv even phoned the place down country who fitted it, (Reciept came with car) and they said it was customer supplied. So i have no way of knowing.
