Hi all,
I've recently bought a G of a friend of mine, he seems to think this issue is caused by the map but I just want a second opinion before I splash out on a new map!
Basically, if I keep at low revs and light throttle it drives fine. If I drive hard and keep it over 2500 it drives fine. The problem is after using full throttle or high revs, once you try cruise at say 2000rpm in 5th is judders and cuts constantly. If I pull over, turn the car off and on then it's fine, until I open it up again.
Any help would be appreciated, I've emailed PPP also.
If it helps im running 65mm pulley, cammed, toothed belt, 250cc, fmic, full engine back system etc.
Thanks a lot.
