Blue temp sender should have a blue 2-pin connector going to it.
Knock sensor has a 3-pin connector, and the wiring harness is shielded cable, so it's easy to identify.
Check what's plugged in to your throttle body switches (white connector), and what's plugged into the CO pot/air temp sensor unit in the boost pipe.
