Author Topic: eaton m45 conversion  (Read 10448 times)
Offline sohailG40
« on: October 19, 2008, 10:43:30 pm »
hi i have a G40 which i want to run the M45 eaton charger on. Can any one plz tell me that if i run the eaton on the standard internals. and wot sort of power i will be looking at thanks.
Offline sohailG40
Re: eaton m45 conversion
« Reply #1 on: October 20, 2008, 10:01:20 pm »
any one help plz
« Reply #2 on: October 20, 2008, 11:41:50 pm »
at the last rolling road day an eaton with standard pulley on an an almost stock car made between 130 and 140 bhp from what i remember
Offline G-spot
« Reply #3 on: October 21, 2008, 09:05:45 am »
The the Eaton type chargers deliver the boost in a different manor to the G-Lader, that is to say that they are good/better at higher RPM's, due to the fact that they rely on fast moving of a small volume, aposed to the G-lader which shifts a larger volume a little slower, in which case your ECU MAP and Std G40 Cam woundn't get the best out of it.  Another thing to consider is that because they compress the air in twin helix screw type arrangement, they produce more heat, in which case you need to look at fitting a larger intercooler(or chargercooler or even water injection system).
To answer your question, yes, it'll work, but but it won't be efficient without other work being done and could result in your engine running lean on top end(which will kill your internals). So no then ???
Offline sohailG40
« Reply #4 on: October 21, 2008, 10:14:41 pm »
i have a front mount on the car but i just have bourght a bigger front mount. I was gonna put some water injectors on it but dont no were i can put the washer bolttle. some one esle said to me to change the injector and get a remap do you think i should do that?
Offline G-spot
« Reply #5 on: October 21, 2008, 10:39:55 pm »
REMAP is a definate I'd say, even with proven know mods its differcult to get the best out of any set-up with an of the shelf MAP, so keep it in mind for your budget.
Offline sohailG40
« Reply #6 on: October 23, 2008, 12:05:34 am »
were would u recomend me putting the water bottel for the intercooler sprayer
Offline sohailG40
« Reply #7 on: October 23, 2008, 12:20:42 am »
and aslo do u no a good place were i can buy a fitting kit for the eaton
« Reply #8 on: October 23, 2008, 09:40:24 am »
I don't think there's anywhere you can buy eaton fitting kits anymore.  AWTracksport used to do them but I'm not sure they still do, plus the strength of them was questionable.  But it might be your only option if yo ucan't either make something yourself or pay an engineer some money to design and make it.
Offline sohailG40
« Reply #9 on: October 23, 2008, 11:36:04 pm »
thanks i will try aw tracsport and see if they do it any way wot kind of g40 do u have
« Reply #10 on: October 24, 2008, 09:36:00 am »
mine has a full blend g40 g-lader at the moment.  Converting it to use a k03 turbo over winter though, have been gathering parts for this for a while.
Offline vwmk3jon
« Reply #11 on: October 24, 2008, 02:32:51 pm »
I should be getting a PSD eaton kit very shortly so i could take measurements of the brackets to hold the charger should anyone need some decent measurements.
Offline sohailG40
« Reply #12 on: October 24, 2008, 10:43:46 pm »
yeh that would be helpful thanks
Offline sohailG40
« Reply #13 on: October 24, 2008, 10:45:46 pm »
yeh i have a full blend g lader at the moment on it but i want high horse power thats y i went to the eaton how cum your getting rid of the supercharger.
Offline vwmk3jon
« Reply #14 on: October 28, 2008, 05:35:18 pm »
got a pic of the bracket but no measurements! If you want it, PM me your email and i'll send it across.
