vacume pipe question
Started by 10pin, August 10, 2011, 11:22:00 PM
10pin
Right on my G40 the pipe from the inlet manifold to the servo has just one  little T off of it for the ECU vacume pipe
and the pipe that connects to the fuel valve comes from the pipe underneath that goes to the ISV
and im not sure if this is correct because my firends servo pipe has two Ts one for the ECU and the other goes to the fuel valve his vacume pipe form the ISV is blanked off
now id like to know which ones is the correct set up and if it would cuase a hesitation i have when revving up
or am i being stupid and it would work either way as they both have vacume its just form pictures ive looked at of engines on here people seem to have differnt set ups for the ECU pipe
any info would be great cheers!
youngprodigys
you should have 2 take offs on the vacuum line mate, i dont think it will work from the line on the ISV - thats for the emissions canister.
get it changed and if your problem still persists then you have problems elsewhere but im sure it shouldnt be like that
can't see it making a difference really, they both just connect to the inlet manifold underneath the throttle plate for a vacuum signal.  but yes they normally have two connections just below the one-way valve on the servo vac pipe.
