Brake pads
Started by grayg40, August 09, 2011, 08:43:24 AM
grayg40
I just phoned my local VW place and they tell me that the front pads are obsolete now since last march, is this true?
And if so where is the next best place to get pads?
I run std size grooved discs
thanks
Mark
dekerf1996
I run ferrodo (DS something) pads on my standard replacement brembo discs.
I find this set up better than the drilled and groved discs and radicam pads I had before.
I would recommend them.
Search on line should reveal a good source
G40BLUE
Quote from: dekerf1996 on August 09, 2011, 12:45:43 PM
Could you please give me the link of your replacement Brembo Discs? I thought to change the discs and the pads mas I need to Know if the configuration to have g40 good =)
Can get the oem brombos from GSF
djtez
ds2500 pads are highly recommended, i use Ebc Green stuff find them ok for normal driving and light to moderate use. Are very dusty tho ..
grayg40 what power output has your polo got? also what style of driving do you have mainly in this car?
G40BLUE
#5
Quote from: hayesey on April 23, 2012, 03:36:42 PM
I'm sorry but you can explain what is GSF?  ::) http://www.gsfcarparts.com/  right?
G40BLUE
Hi,
so I'm thinking to buy Brembo Max + EBC Green Stuff or Brembo Max + Ferodo DS Performance. Some people informed that the first one is very good, someone told that for best performance I must use Tarox g88 with Ds 2500, but more expensive.What you suggest?
Another thing that I want to put steel Mesh what I shoud do in your oppinion.
thanks very much for you Help
GBlue
djtez
i use brembo max (grooved) discs at the moment and ebc green stuff.
is ok .. but not enough for a high powered g40, on a lightly modded polo this would be fine.
i do not understand "i want to put steel mesh" .. where are you wanting to put the steel mesh ?
Terry
G40BLUE
Quote from: djtez on April 24, 2012, 10:33:15 AM
Terry
I'm Sorry Cables steel mesh. Replace rubber Cables :)
djtez
ah, here we call them "braided hoses"
they are stainless steel braided lines,
you can buy them from Goodrich website. (they are listed as mk1 golf)
G40BLUE
#10
Ah ok Thanks for your Help.
Just one thing, put braided hoses is a good solution or not justified?
djtez
Good solution as this reduces brake pedal travel.
Rubber slightly expands where steel stas rigid.
Hope this explains
grayg40
i forgot about this post, i got pads from venom ms, black diamond ones!
they work well with the matching grooved disks
Quote from: G40BLUE on April 23, 2012, 04:04:05 PM
Yeah.  Didn't realise you weren't in the uk though!
G40BLUE
Quote from: hayesey on April 24, 2012, 02:39:06 PM
No problem :)
