Author Topic: Pitstop developments oil system  (Read 7620 times)
Offline dubdetail
« on: July 24, 2011, 12:29:50 pm »
Hello,
I'm Pim and running a business back in Holland. I design and manufacture custom car parts mainly for VW.
On the Moment we're building a demo car. Its a Polo G40 with a large list of upgrades.
At first we want to run the G40 RS2 charger with 62mm toothed belt drive. But with such high charger speeds we plan to run a separate oil system for the charger with a special kind of lubricant to get the best lubrication possible.
With the standard set-up thick engine oil with particles and so, will flow through the charger on fluctuating oil pressures.
I've read on the net that Pitstop developments had such a system. The system is not that hard to design and will be pretty straight forward.
The problem is that i don't know the type of oilpump used by pitstop developments.
Does anyone know which pump was used by pitstop developments?
Earger to know.
The speclist of the demo car:
Block:
-Oversized wossner 76mm Pistons.
-Custom made H-beam Rods.
-Lightened and balanced Crank.
-Lightened and balanced Flywheel.
-Custom designed torque plate to connect the mains to hold them in place during big engine loads and high rpm's.
-Mains fitted with ARP Studs.
-Custom uprated oilpump.
-Waterpump.
-Custom all steel layered head gasket.
-Piston bottom cooled by oil jets.
-Custom dry-sump oil system.
Head:
-Custom ported en polished head.
-Custom valves cut to spec to enable the best possible flow.
-Custom valve guides
-Mechanical valvetrain with solid lifters. (9500rpm)
-Custom springs with titanium caps.
-Custom Billet intake manifold.
-Custom 70mm Throttle valve.
-Custom manifold and exhaust line stainless.
Gearbox:
-Standard internals.
-Helix custom clutchset.
-Qaiffe diff.
-Custom driveshafts.
Chassis:
-Intraxx coilover set.
-Custom sub-frame.
-Custom torque beams on the rearaxle.
-lightweight wings, bootlit and tailgate.
-Polycarbonate side and rear windows.
-FIA Rolcage
Charger:
-RS2 G40 Charger.
-Custom beltdrive kit 62mm pully.
-20mm timing belt.
-Water to air intercooler.
-Separate oil system.
And This list will grow.
Greets, Pim Bonne
Dub-Detail
Offline Jezza-7
Re: Pitstop developments oil system
« Reply #1 on: July 24, 2011, 02:33:51 pm »
Hi and welcome. They used facet fuel pumps and very thin oil like compressor oil. I used to run one but it failed so i got a proper oil pump from mocal for the kit. Works a lot better and i can use better oil for the g-lader.
Offline cheddarcheese
  • i like boobs!
    • supercharged
« Reply #2 on: July 24, 2011, 03:39:37 pm »
yep a facet fuel pump was used but a proper oil pump like mentioned would be more ideal also oil pressure gauge will be needed so you know if any thing fails!
but if you do use a facet i think you need a fuel pressure gauge instead.
also i have a psd charger standalone oil kit with a facet fuel pump for sale!
Offline dubdetail
« Reply #3 on: July 24, 2011, 03:53:18 pm »
Thanks lads,
Chaddarcheese, could you sent me a PM or mail me at info@dubdetail.com
Thanks,
Pim Bonne
Dub-Detail
Offline Andy
« Reply #4 on: July 24, 2011, 06:15:12 pm »
9,500rpm and a 62mm pulley. :o
What bearings and seals will you be using in the 'charger?
Offline dubdetail
« Reply #5 on: July 24, 2011, 07:17:21 pm »
The cylinderhead will be capable to handle 9500rpms safe.
I think max power would be achieved between 7000 and 8000rpm. We decided to convert to solid lifters right from the start, so be dont't need to change that when we blow the g40 to haven. After that we'il use a custom made hybrid turbo. And to only way to let that sucker spinn up to boost is displacement gasflow. Since we'il only have 1400cc available we've to make rpm's to get the gas flowing.
Nevertheless, bearings and seals will be chosen later in the progress.
I've got a good connection by skf. They can give me good advice.
Pim Bonne
Dub-Detail
« Last Edit: July 24, 2011, 10:06:28 pm by dubdetail »
Offline Jezza-7
« Reply #6 on: July 25, 2011, 08:52:07 am »
Offline dubdetail
« Reply #7 on: July 25, 2011, 10:24:10 am »
This is the pump i now use just incase you wondered.
http://www.merlinmotorsport.co.uk/p3652/MOCAL-ELECTRIC-OIL-PUMP/product_info.html
Thanks,
I allready did find such a pump.
Set for G-chargers is already designed:
Number 6 is a option, (it's a thermostat operated oil cooler) because i think de g-charger would not heat the oil that fast with normal use.
1. Charger
2. Catchtank
3. Oil pump
4. Oilfilter
5. Pressure regulator
6. Sandwichplate with thermostat and oil cooler sytem.
For turbo's the system would be the same, only with a bigger catch-tank and a larger oil cooler.
Also the oil line between 1 and 2 will be much larger.
With the pressure regulator i'm using come's a nice feature, it sends the adjusted amount of oil-pressure to the charger and the rest is redirected to the catch tank. Picked up by the pump and send through the circuit again. Doing so will keep the temperature in control. When the oil becomes to hot, the thermostat opens and sends the oil through the cooler.
Pim Bonne
Dub-Detail
« Last Edit: July 25, 2011, 11:59:49 am by dubdetail »
Offline Jezza-7
« Reply #8 on: July 25, 2011, 11:49:08 am »
Interesting. Your pic hasn't worked.
Offline dubdetail
« Reply #9 on: July 25, 2011, 11:57:39 am »
Hmm, on my pc it's working fine.
Tryed again.
For lubrication we use a custom blended oil, It's comparable with gasturbine oil.
But because that oil is poisonous we'il use a non toxic blend.
Pim Bonne
Dub-Detail
« Last Edit: July 25, 2011, 12:04:05 pm by dubdetail »
« Reply #10 on: July 25, 2011, 12:07:03 pm »
pic is working now.  sounds like a very interesting project, please keep us posted with the progress!
The PSD kits never used a cooler or a proper oil pump, they were built to a price in order to sell.  A proper oil pump would have increased the price by £150 or more and I doubt anyone would have bought one.  But for your own project if money isn't a problem then a proper oil pump is better.
I never used a cooler on mine either, the header tank full of oil is a good enough heat sink, the charger doesn't put too much heat in (unlike a turbo as I now have but this just lubricates from the engine oil).  I also just had a 65mm pulley on.
Offline dubdetail
« Reply #11 on: July 25, 2011, 12:43:44 pm »
Pricing is not that high. I'm planning to sell the kits after the system is tested properly.
The basic kit will be around €300,- (£264,81) (catch-tank, facet pump, remote oil-filter, regulator and hoses)
And the basic kit can be uprated with different pumps, coolers etc.
The kit will not only work on g-chargers but also on turbo's.
The engine's oil holds particles in it. These particles build up in the turbo's oil system especially at the hot side bearings and oil return pipe.
Using a special oil prevents particle from building up and keeps the system clean and smooth, the only problem is that the engine can't handle such oil and the engine is the main reason those particles are in the oil.
On normal street cars these particles are not that kind of a issue because temperatures will stay within the limits. But on tuned cars this will give problems as the temperatures are much higher.
We have to change turbo's on a regular basis because particle build up prevents the oil from flowing. And as that happens the turbo's days are counted.
So with the system on it, the turbo will operate on clean special blended oil.
The particle contamination is much slower. So build-up does not occur.
The turbo lives longer a can handle more stress/heat.
Engine oil keeps cooler
Oil pipes don't have to be changed because they stay clean.
And when you shut they engine down, the system can keep the oil flowing untill the turbine stops spinning.
Pim Bonne
Dub-Detail
Offline Jezza-7
« Reply #12 on: July 25, 2011, 03:21:09 pm »
What oil are you going to use? Sounds interesting.
« Reply #13 on: July 25, 2011, 03:28:14 pm »
well yes, using a Facet fuel pump, price is OK.  I meant that if PSD had used a proper oil pump then it'd go too high and most people probably wouldn't be willing to pay the money.
Offline dubdetail
« Reply #14 on: July 25, 2011, 04:05:22 pm »
actually, iv got 4 pumps to choose from.
€ 70,--Facet
€125,--Brandless diaphragm pump
€180,--Mocal diaphragm pump
€160,--Brandless spurrgeared pump
€250,--Industrial spurrgeared pump
Pim Bonne
Dub-Detail
