Author Topic: Oil feed fitting size  (Read 5406 times)
Offline Winston
« on: May 03, 2011, 01:24:42 pm »
Hi folks
Does any body know what fitting size is used to connect the oil feed to the pressure sensor feed on the back of the head?
Just a quick other question while im here... Do I need to drill out the oil pressure feeds out the back of the head to gain more flow?
Winston
Offline cheys03
Re: Oil feed fitting size
« Reply #1 on: May 03, 2011, 01:39:56 pm »
M10x1mm.
I have a K03 and 'port' in the head doesn't seem to be a problem, nor have I ever heard of anyone enlarging it. Should be fine providing the hose is suitable.
Offline Winston
« Reply #2 on: May 03, 2011, 01:58:38 pm »
Cheers dude.. Thats perfect I can get the hose ordered from hose solutions this afternoon ;D
I hadn't seen anyone enlarging it in any build threads but I just had to ask with it looking so small compared to the size of the hose  8)
Offline grantvw
« Reply #3 on: May 03, 2011, 09:00:04 pm »
I've enlarged my hose  ???
Offline cheys03
« Reply #4 on: May 03, 2011, 11:16:54 pm »
Yeah I think the hose needs to be bigger, but the port itself is OK.
Offline vwmk3jon
« Reply #5 on: May 03, 2011, 11:38:41 pm »
My oil feed pipe looks a tad small (like a G-lader item)
Offline evans.I
« Reply #6 on: June 20, 2011, 09:40:55 pm »
Hi, can anybody confirm the hose specs for the feed to K03 before I order from Hose Solutions.
Specs I have:
*Stainless braided hose (-4).  Length 600mm.
*M10x1mm banjo fitting
*M12x1.5mm male right-angle fitting
*M10x1mm banjo bolt and copper washers
Thanks, Ian.
Offline cheys03
« Reply #7 on: June 20, 2011, 10:58:52 pm »
Aye, those are the specs I PM'd you ;)
Edit: It's worked out well for me. Length includes the fittings.
M12x1.5mm male right-angle fitting fits better if it's not a banjo, it's better straight-on....if you know what I mean...
« Last Edit: June 20, 2011, 11:04:18 pm by cheys03 »
Offline evans.I
« Reply #8 on: June 20, 2011, 11:27:48 pm »
As in just a male thread straight into the oil feed port in the housing?.....if i'm correct in knowing what you mean....... :P
Offline cheys03
« Reply #9 on: June 20, 2011, 11:42:41 pm »
hehe. Picture a thousand words 'n all that:
Hose solutions sent me an adapter to fit their hose (in the pic)... I just emailed them the specs above and they sorted it all inc the adapter but not the M10 banjo bolt for £30 delivered iirc.
Edit: Adapter is on the turbo end, not the T-piece into the head
« Last Edit: June 20, 2011, 11:45:41 pm by cheys03 »
Offline evans.I
« Reply #10 on: June 20, 2011, 11:48:23 pm »
Thankyou so much, i'll get the specs over to them asap then. Thats one less thing on the never ending list to worry about  ;D
Ian.
Offline cheys03
« Reply #11 on: June 20, 2011, 11:53:00 pm »
No worries, happy to help :)
Wait 'till you have to sort the boost pipes, now they're a headache!
Offline vwmk3jon
« Reply #12 on: June 21, 2011, 01:56:03 am »
haha yeah. Took mine out and put em back in 3 times to get them to line up properly!!!!
Offline Winston
« Reply #13 on: June 25, 2011, 02:21:20 pm »
I just ended up sending Ben the fittings from the turbo and Oil preasure banjo and the length I required.. as I wasn't sure what fitting my turbo was.
Offline vwmk3jon
« Reply #14 on: June 27, 2011, 12:25:31 am »
shame i cant upload pics. My bays looking mighty fine :)
