Technical => Turbochargers => Topic started by: Winston on May 03, 2011, 01:24:42 pm
Title: Oil feed fitting size
Post by: Winston on May 03, 2011, 01:24:42 pm
Hi folks
Does any body know what fitting size is used to connect the oil feed to the pressure sensor feed on the back of the head?
Just a quick other question while im here... Do I need to drill out the oil pressure feeds out the back of the head to gain more flow?
Winston
Title: Re: Oil feed fitting size
Post by: cheys03 on May 03, 2011, 01:39:56 pm
M10x1mm.
I have a K03 and 'port' in the head doesn't seem to be a problem, nor have I ever heard of anyone enlarging it. Should be fine providing the hose is suitable.
Post by: Winston on May 03, 2011, 01:58:38 pm
Cheers dude.. Thats perfect I can get the hose ordered from hose solutions this afternoon ;D
I hadn't seen anyone enlarging it in any build threads but I just had to ask with it looking so small compared to the size of the hose  8)
Post by: grantvw on May 03, 2011, 09:00:04 pm
I've enlarged my hose  ???
Post by: cheys03 on May 03, 2011, 11:16:54 pm
Yeah I think the hose needs to be bigger, but the port itself is OK.
Post by: vwmk3jon on May 03, 2011, 11:38:41 pm
My oil feed pipe looks a tad small (like a G-lader item)
Post by: evans.I on June 20, 2011, 09:40:55 pm
Hi, can anybody confirm the hose specs for the feed to K03 before I order from Hose Solutions.
Specs I have:
*Stainless braided hose (-4).  Length 600mm.
*M10x1mm banjo fitting
*M12x1.5mm male right-angle fitting
*M10x1mm banjo bolt and copper washers
Thanks, Ian.
Post by: cheys03 on June 20, 2011, 10:58:52 pm
Aye, those are the specs I PM'd you ;)
Edit: It's worked out well for me. Length includes the fittings.
M12x1.5mm male right-angle fitting fits better if it's not a banjo, it's better straight-on....if you know what I mean...
Post by: evans.I on June 20, 2011, 11:27:48 pm
As in just a male thread straight into the oil feed port in the housing?.....if i'm correct in knowing what you mean....... :P
Post by: cheys03 on June 20, 2011, 11:42:41 pm
hehe. Picture a thousand words 'n all that:
(http://i734.photobucket.com/albums/ww343/cheys03/Build%20thread/Turbo/th_3514d793.jpg) (http://s734.photobucket.com/albums/ww343/cheys03/Build%20thread/Turbo/?action=view&current=3514d793.jpg)
(http://i734.photobucket.com/albums/ww343/cheys03/Build%20thread/Turbo/th_85a66250.jpg) (http://s734.photobucket.com/albums/ww343/cheys03/Build%20thread/Turbo/?action=view&current=85a66250.jpg)
Hose solutions sent me an adapter to fit their hose (in the pic)... I just emailed them the specs above and they sorted it all inc the adapter but not the M10 banjo bolt for £30 delivered iirc.
Edit: Adapter is on the turbo end, not the T-piece into the head
Post by: evans.I on June 20, 2011, 11:48:23 pm
Thankyou so much, i'll get the specs over to them asap then. Thats one less thing on the never ending list to worry about  ;D
Ian.
Post by: cheys03 on June 20, 2011, 11:53:00 pm
No worries, happy to help :)
Wait 'till you have to sort the boost pipes, now they're a headache!
Post by: vwmk3jon on June 21, 2011, 01:56:03 am
haha yeah. Took mine out and put em back in 3 times to get them to line up properly!!!!
Post by: Winston on June 25, 2011, 02:21:20 pm
I just ended up sending Ben the fittings from the turbo and Oil preasure banjo and the length I required.. as I wasn't sure what fitting my turbo was.
(http://i64.photobucket.com/albums/h175/76ball/Mk1%20Scirocco%20Blog/IMG_2001.jpg)
Post by: vwmk3jon on June 27, 2011, 12:25:31 am
shame i cant upload pics. My bays looking mighty fine :)
