A few other 'hidden' costs to consider:
Injectors (250cc or 310cc dependant on power)
Fuel Pumps (replace/ uprate dependant on power)
Rad fan- stock item isn't really up to the job with the extra heat from the turbo into the
cooling circuit.
Forge Actuator (K03)- Adjustable boost levels
Camshaft- Newman/Schrick etc to suit capacity and turbo
Oil drain fittings
Silicone hose (don't underestimate the cost of doing this properly!)
Dump valve
Map to suit (or custom remap)
Clutch
Chassis/brake mods to cope with power!
It all depends how far you want to take things, for a good budget 170bhp that's reliable I'd run the following spec:
250cc injectors, stock map sensor, K03 with either forge actuator and 15psi spring, or stock with bleed valve (not ideal), large front mount intercooler, and a 63mm downpipe to a 2.5" system, rothe cast manifold (flow 220bhp+ and won't crack!) and an organic clutch.
That's a turbo setup, that with an injector/map and boost increase will make 190bhp+
I.e spend money early and make it 170bhp, get used to it, then upgrade for a few hundred to 190bhp+
