Re: 51mm Throttle Body Conversions - 1 Available!
Started by Justin14100, February 20, 2011, 09:55:18 PM
Justin14100
51mm Throttle Body Conversions are now available.
What this service gives is an enlarged throttle body on an exchange basis for your old unit.
The 51mm throttle body is enlarged from 45mm; this allows more air to pass through the unit with less restriction.
What the unit consists of are the following: Opening up the main body to 51mm; an elliptical and chamfered butterfly to suit the unit, use of cap head screws on the butterfly to reduce restriction; ported and matched top elbow to further reduce restrictions and slightly improve flow; sealant used between the top elbow and the main unit to prevent boost leaks. We now use chemical metal to strengthen the weakest wall of the throttle body, which is behind the cover for the wide open throttle sensor so luckily it doesn't degrade the look of the throttle body.
These enlargements will change how the throttle feels on your car, its more sensitive, more aggressive with an increase of power. I've really enjoyed having one on my daily, feels more torquey off boost low end and mid range which is always nice.
Much time has been spent making sure sure the butterfly gives a perfect seal and the quality of the OEM is retained.
Prices are as £150 exchange, once payment and your original Throttle Body is with us yours will be sent out. If you car is a daily or you don't want it off the road for a day or two PM me and we may be able to sort something out.  Any questions or specific needs please PM me.
breadman
I will take the other one only after the main body though. Please pm your payment details and price for main body only thanks.
Justin14100
Just a heads up for anyone thats interested, I will have 3 throttle bodies available the week starting the 6th of February. I have changed the description a little too as we no longer sand blast them, the dirt would contaminate the tiny needle bearings that rest on the butterfly shaft so it would make it feel a little 'gritty' and not smooth.
Regards,
Justin.
PM me for details.
Justin14100
djtez
Justin14100
New batch arriving next week with brass butterflies instead of aluminium ones, they will still come sealed with black silicone gasket but if you want a 51mm gasket please enquire here:
http://www.polog40.co.uk/forum/index.php/topic,8439.0.html
Send randombadger a PM and he will sort you out if you choose to run that solution.
beatboxG40
tjp_lawson
Justin14100
Ok guys, the time in the machine shop is booked. This will be the last chance I will get before I leave (unless there is a special case of power urgency!
I have three throttle bodies ready to be machined, however if you send yours over for the weekend I will turn them around and post on Monday or Tuesday so I can get as many done as possible.
Please PM me for further details.
Justin14100
Due to high demand some more will be being made this weekend. So there should be a few available in the first part of September
PM me for details
Thanks!
jez1272gt
Just had one of these delivered in the post from Justin and i must say i am most impressed with the quality of the machining/work. Very fast turn around from him... spot on thanks mate...
vee-dub90
Justin14100
Final batch finished, I have a few available. PM me for details, I would prefer these to be exchanged before I leave on the 18th but can make other arrangements if necessary.
