Newman Camshafts
Started by Phil, February 09, 2011, 12:10:59 AM
Phil
Can supply Newman camshafts for the G40 for £200 delivered.
Please specify whether you'd like a G40 fast road, G40 turbo, or if you want something lairer than either, it can be arranged.
G_CoNeCtioN
hi can you arrang me the race 290/290 ones??
Phil
I can indeed, what application is this for? Anf how much lift would you like?
poloeatonm45
can you get the for the eaton that psd used to sell?
steve
Richg40
Quote from: poloeatonm45 on March 17, 2011, 07:23:33 PM
steve
Seconded. Yes please.
Phil
Eaton cam won't be a problem, did you want one for a stock or 1341 engine?
Richg40
poloeatonm45
Did psd ever make one for a 1500? If they did I want one too
Steve
Do the fast road cams need a vernier pulley Phil?
Richg40
zzzzzzzzzzz   zzzzzzzzzz  zzzzzzzzz!
josé
i think your best bet is to pm phil over on clubpolo
I just bit the bullet and bought one, but not from Phil. Hope it's a straight fit and doesn't need a vernier.
poloeatonm45
If you are talking about an eaton cam I never ever got mine fitted I tried everything and just could not get it to run on any more than 2 cylinders. I don't know if I had a dodgy cam or what but it just would not run even when we tried it with a venier pully. If anyone could help or offer any advice I would be really greatfull
Steve
Phil
Apologies, custom spec is no problem at all. Just let me know what its going in and I can work it out. PSD would have just done the same, already worked out an ideal spec for the 1500 eaton for someone else.
Doesn't need a vernier, but it is better for getting the most out of your setup.
