My gearbox mount cracked!!
Started by Jezza-7, January 30, 2011, 04:51:24 PM
Took this off today to replace the mount with a poly one and found this on the mount:
1st crack
2nd crack
3rd crack possibly a 4th
by that welding, it looks like a PPS one, not a PPP one
Sorry forgot to mention it is a PPS one NOT PPP!
Cheers Pete
haha exactly what i said to my mate. Im gonna get a ppp subframe if yoof has any if not, im gonna go back to the original setup.
Can you fit the original gearbox mount with a subframe?
Alexiskayak_7
Quote from: Jezza-7 on January 30, 2011, 05:13:54 PM
Νο, it has no space... i thing that the gearbox mount will hit the frame...
Why don't you contact with the maker and replace or re-weld the broken part?
cheys03
Quote from: Alexiskayak_7 on January 30, 2011, 05:19:30 PM
Would you trust your life to that quality of welding? Even if you repaired the gearbox mount to a decent level, the rest of the subframe is still suspect.
Nick_S
This goes to show the inportance of CE & BS certified items, whether it be engine or chassis related. You would have trouble in a accident investigation getting a payout if dodgy parts are found to be the root cause. Thats why I paid extra for KW's, TUV approval cetificate with them...
Alexiskayak_7
Quote from: cheys03 on January 30, 2011, 05:28:41 PM
Definately not mate...
No i wouldn't wanna trust that at all!
The frame is staying on for 2 weeks then once its mot is done its coming off the road for engine stuff and thats when the frame will be coming off too!
The frame appears to be ok though. Will get a better look at it on a ramp but until then i cant do much.
cheys03
#10
What have you been using the frame and car for Jezza? Light on-road use or full on track hammering? And are your other engine mounts OK - i.e. not too worn and putting extra strain on the rear mount?
Just road. It has covered around 12k i think.
leeg40
Hhmmm, a case of S**T welding.com, if you think the frame is suspect get the paint off the welds then get them MPI/DPI inspected, and repaired if required.
cheys03
youngprodigys
id strip the paint off off the important areas on the subframe (welds near control arms) and make sure there are no cracks.
we shouldn't jump to conclusions on the rest of them frame - this could be a one off bad weld. and i cant quite see from the photos - but is there anyway the installation could have had an impact on the cracks?
im not implying you have put it on wrong - more that when putting it on the clamping onto the gearbox the bolts have bent the bracket inwards/outwards??? or that the mount wasnt straight? putting it under load in the wrong plane.
Not every engine will sit in the bay the same way as you have 2 mounts either side of the engine which you can move 3-4mm forwards/backwards. when i first put my engine in and did it up it was sloping and twisted until i straightened it out on the mounts.
think this thread may have had a few people looking under there cars at this part!!!
