Author Topic: DOH!!!! trapped my knock sensor wire  (Read 2284 times)
Offline youngprodigys
  • G 3URO
« on: December 24, 2010, 07:53:00 pm »
Hey guys - trapped my knock sensor wire with the screw which holds down the ISV (between the waterpipe and the screw) and it now has a mark in the wire so im replacing it (genuine only)
Question - has anyone used a newer knock sensor? the part number is 030 905 377 and i know a few 20v turbos use 030 905 377 H
is it the same part but with a longer cable or is it a different frequency? - anybody know???
im sure Andy will know the answer to this.
im looking forward to spending £60 at the dealer for this stupid mistake
  • G 3URO
Re: DOH!!!! trapped my knock sensor wire
« Reply #1 on: December 26, 2010, 07:59:34 pm »
right a bit of research is showing me that the part number along with a letter on the end "A C H etc" just denotes wire length- sensors are the same.
Offline cheys03
« Reply #2 on: December 26, 2010, 10:16:42 pm »
Great info. Could you list the part numbers and cable lengths please? Many thanks
Offline Andy
« Reply #3 on: December 27, 2010, 06:35:03 pm »
Sensor is just a pietzo microphone, so I'd imagine any one will do.
  • G 3URO
« Reply #4 on: December 27, 2010, 06:35:29 pm »
well the stock G40 knock sensor has the code
030 905 377 and bosch 0261231066 and is 300mm long
golfs of the same year have
054 905 377 A and is 740mm long and green connector
054 905 377 G and is 535mm long and blue connector
and a quick browse on the net shows they have the same bosch part number but the last 3 digits differ - and again according to the datasheet - this denotes length
here is the bosch website which gives you this data sheet where they point out the later part of the part number denotes length
http://www.bosch.com.au/content/language1/downloads/sensors_knock.pdf
  • G 3URO
« Reply #5 on: December 27, 2010, 06:37:12 pm »
and as Andy is the man in the know - this will confirm im right! should be all the same:-) il go and get one 2moro now from the breakers. and once installed check using VWtool for error codes
Offline cheys03
« Reply #6 on: December 27, 2010, 07:50:51 pm »
Great, cheers. Useful info there.
