Author Topic: headgasket overhaul  (Read 6371 times)
Offline djtez
  • aaAAHH CHOOO!
    • its ma bebo site
headgasket overhaul
« on: September 05, 2008, 09:48:39 pm »
My car just the other day encountered a problem (head gasket)
i knew all the sypthoms and proceeded yesterday to strip the head off..
i took out the cam first which had marking on the dizzy end (bp 27 ohy g40) and few other figures..
not all clear but i will try take a foto. is this a Standard cam?!!
i am very interested and concerned about the gasket replacment..
wat gasket should i buy.. i didn't think high compression was good for the g40?
im worried about skimmin the head? can i get a thicker gasket?
some one mentions on clubpolo about a metal gasket
Re: headgasket overhaul
« Reply #1 on: September 05, 2008, 10:25:43 pm »
see my post in yr other post
Re: Re: headgasket overhaul
« Reply #2 on: September 05, 2008, 10:43:17 pm »
I guess that "someone" would be me :)
I wouldn't worry in the slightest about skimming the head reducing compression ratio.  The g40 has the combustion chamber in the pistons with a pretty much flat head so skimming the head makes such a small difference to compression ratio you needn't worry about it, as I said on clubpolo.
The metal gasket is from a mk4 polo 8v engine and will raise compression if you want it to be higher.
Offline djtez
  • aaAAHH CHOOO!
    • its ma bebo site
Re: Re: Re: headgasket overhaul
« Reply #3 on: September 05, 2008, 10:47:18 pm »
can i have a part number for this
is this a 1.3 cl out the 6n polo?
this my best option.. i have noticed a post on this site about a psd gasket?
not much difference no ?
Re: Re: Re: Re: headgasket overhaul
« Reply #4 on: September 05, 2008, 11:08:13 pm »
it's the one from the MPI engines, 1.4, 1.6.  Look for the one for AEX engine code on GSF website.
Offline Rob
Re: Re: Re: Re: Re: headgasket overhaul
« Reply #5 on: September 06, 2008, 11:49:11 am »
GSF part number - 030-103-383AH is what i have used
HTH
Offline djtez
  • aaAAHH CHOOO!
    • its ma bebo site
Re: Re: Re: Re: Re: Re: headgasket overhaul
« Reply #6 on: September 09, 2008, 12:50:04 pm »
ok thanks , im not argueing against your knowledge but how does a 1.4 or 1.6 gasket fit on a 1.3 ??
are the water channels still the same ?
Re: Re: Re: Re: Re: Re: Re: headgasket overhaul
« Reply #7 on: September 09, 2008, 12:56:37 pm »
yes they are!
Offline djtez
  • aaAAHH CHOOO!
    • its ma bebo site
Re: Re: Re: Re: Re: Re: Re: Re: headgasket overhaul
« Reply #8 on: September 09, 2008, 01:13:17 pm »
ahh thank you.. im ordering the parts RIGHT NOW lol :D excited but im stuck lol
i've got a head gasket .. rocker gasket.. sump gasket(i need one)
inlet and exhaust..
which valve stem seal do i need!!
is the one (all engine fitted with 6mm valves) ? wat else ... i cant think.. brain.. freeze ahhhh
Offline djtez
  • aaAAHH CHOOO!
    • its ma bebo site
Re: Re: Re: Re: Re: Re: Re: Re: Re: headgasket overhaul
« Reply #9 on: September 09, 2008, 01:18:12 pm »
im confused with findin a camshaft seal? my one when i took the cam out the little spring that i assume holds the seal tight to the cam wasen't holding in place..
so ill just replace it
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: headgasket overhaul
« Reply #10 on: September 09, 2008, 01:43:56 pm »
cam/crank oil seal are teh same bit...      you also need 10x headbolts
Offline djtez
  • aaAAHH CHOOO!
    • its ma bebo site
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: headgasket overhaul
« Reply #11 on: September 09, 2008, 02:01:15 pm »
Part Number      Description      Fitment      Price(£)      Quantity      Delete
11028    VALVE COVER GASKET    PO 1.3 75 BHP 10/90 >7/94      3.75    1    Delete
11805    INLET MANIFOLD GASKET    PO G40 10/90 >7/94      2.50    1    Delete
11830    EXHAUST MANIFOLD GASKET (2 required per car)    PO 0.9-1.3      3.00    2    Delete
11133B    CYLINDER HEAD GASKET    PO 1.4 / 1.6 ADX/AEA/AEX Engines 94>      15.60    1    Delete
11615    SUMP GASKET    PO 1.3 1/77 >7/95      4.85    1    Delete
14414    EXHAUST VALVE    PO G40 10/90 >7/94      5.60    4    Delete
01161    CYL.HEAD BOLT+WASHER-11mm    PO G40 10/90 >7/94      1.00    10    Delete
11740    OIL SEAL-CAM/INT/CRANK BQ    PO 1.3 75 BHP 9/82 >9/90      5.90    1    Delete
TOTAL(exc. VAT & Delivery)       £ 71.00
Delivery(UK)     Free Delivery
VAT      £ 12.43
TOTAL      £ 83.43
this all good or am i missing something
Offline djtez
  • aaAAHH CHOOO!
    • its ma bebo site
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: headgasket overhaul
« Reply #12 on: September 09, 2008, 03:28:54 pm »
which dizzy cap is for the g ??
https://secure.gsfcarparts.com/shop/results.asp
plus theres two spark plugs
w5dtc and w5dpo i;ve heard of the second one but dpo is 10. a plug and the other like 3 or summin..
« Last Edit: September 09, 2008, 03:32:03 pm by djtez »
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: headgasket overhaul
« Reply #13 on: September 09, 2008, 03:29:33 pm »
link no worky... ring em up  = would be easier!
Offline djtez
  • aaAAHH CHOOO!
    • its ma bebo site
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: headgasket overhaul
« Reply #14 on: September 09, 2008, 04:09:02 pm »
*  Click here to perform a new search.
18723    SEAL RING-INJECTOR LARGE    General Use Most Late Inj. 85>      0.60    4    Delete
28212    EXHAUST DOWN PIPE GASKET    PO 1.3 75 BHP All      1.80    1    Delete
MMW712/52    OIL FILTER    PO 1.3 Inc. G40 10/90 >7/95      3.25    1    Delete
18726    SEAL RING-INJECTOR SMALL    General Use Most Late Inj. 85>      0.60    4    Delete
92218    IGNITION ROTOR ARM    PO G40 10/90 >7/94      3.95    1    Delete
92133    DISTRIBUTOR CAP    G2 1.3 5/90 >7/92 Bosch Type -Shroud      4.95    1    Delete
TOTAL(exc. VAT & Delivery)       £ 67.35
VAT      £ 11.79
TOTAL      £ 79.14
just ordered this..
cant think anything else... gsf dont do the studs.. foned them up
