Technical => Engine and Transmission => Topic started by: djtez on September 05, 2008, 09:48:39 pm
My car just the other day encountered a problem (head gasket)
i knew all the sypthoms and proceeded yesterday to strip the head off..
i took out the cam first which had marking on the dizzy end (bp 27 ohy g40) and few other figures..
not all clear but i will try take a foto. is this a Standard cam?!!
i am very interested and concerned about the gasket replacment..
wat gasket should i buy.. i didn't think high compression was good for the g40?
im worried about skimmin the head? can i get a thicker gasket?
some one mentions on clubpolo about a metal gasket
see my post in yr other post
I guess that "someone" would be me :)
I wouldn't worry in the slightest about skimming the head reducing compression ratio. The g40 has the combustion chamber in the pistons with a pretty much flat head so skimming the head makes such a small difference to compression ratio you needn't worry about it, as I said on clubpolo.
The metal gasket is from a mk4 polo 8v engine and will raise compression if you want it to be higher.
can i have a part number for this
is this a 1.3 cl out the 6n polo?
this my best option.. i have noticed a post on this site about a psd gasket?
not much difference no ?
it's the one from the MPI engines, 1.4, 1.6. Look for the one for AEX engine code on GSF website.
GSF part number - 030-103-383AH is what i have used
HTH
ok thanks , im not argueing against your knowledge but how does a 1.4 or 1.6 gasket fit on a 1.3 ??
are the water channels still the same ?
yes they are!
ahh thank you.. im ordering the parts RIGHT NOW lol :D excited but im stuck lol
i've got a head gasket .. rocker gasket.. sump gasket(i need one)
inlet and exhaust..
which valve stem seal do i need!!
is the one (all engine fitted with 6mm valves) ? wat else ... i cant think.. brain.. freeze ahhhh
im confused with findin a camshaft seal? my one when i took the cam out the little spring that i assume holds the seal tight to the cam wasen't holding in place..
so ill just replace it
cam/crank oil seal are teh same bit... you also need 10x headbolts
Part Number Description Fitment Price(£) Quantity Delete
11028 VALVE COVER GASKET PO 1.3 75 BHP 10/90 >7/94 3.75 1 Delete
11805 INLET MANIFOLD GASKET PO G40 10/90 >7/94 2.50 1 Delete
11830 EXHAUST MANIFOLD GASKET (2 required per car) PO 0.9-1.3 3.00 2 Delete
11133B CYLINDER HEAD GASKET PO 1.4 / 1.6 ADX/AEA/AEX Engines 94> 15.60 1 Delete
11615 SUMP GASKET PO 1.3 1/77 >7/95 4.85 1 Delete
14414 EXHAUST VALVE PO G40 10/90 >7/94 5.60 4 Delete
01161 CYL.HEAD BOLT+WASHER-11mm PO G40 10/90 >7/94 1.00 10 Delete
11740 OIL SEAL-CAM/INT/CRANK BQ PO 1.3 75 BHP 9/82 >9/90 5.90 1 Delete
TOTAL(exc. VAT & Delivery) £ 71.00
Delivery(UK) Free Delivery
VAT £ 12.43
TOTAL £ 83.43
this all good or am i missing something
which dizzy cap is for the g ??
https://secure.gsfcarparts.com/shop/results.asp
plus theres two spark plugs
w5dtc and w5dpo i;ve heard of the second one but dpo is 10. a plug and the other like 3 or summin..
link no worky... ring em up = would be easier!
* Click here to perform a new search.
18723 SEAL RING-INJECTOR LARGE General Use Most Late Inj. 85> 0.60 4 Delete
28212 EXHAUST DOWN PIPE GASKET PO 1.3 75 BHP All 1.80 1 Delete
MMW712/52 OIL FILTER PO 1.3 Inc. G40 10/90 >7/95 3.25 1 Delete
18726 SEAL RING-INJECTOR SMALL General Use Most Late Inj. 85> 0.60 4 Delete
92218 IGNITION ROTOR ARM PO G40 10/90 >7/94 3.95 1 Delete
92133 DISTRIBUTOR CAP G2 1.3 5/90 >7/92 Bosch Type -Shroud 4.95 1 Delete
TOTAL(exc. VAT & Delivery) £ 67.35
VAT £ 11.79
TOTAL £ 79.14
just ordered this..
cant think anything else... gsf dont do the studs.. foned them up
