Toothed Pulleys
Started by xrrich, December 10, 2010, 12:13:29 PM
xrrich
Hi recently upgraded to a 65mm pulley and im getting alot of belt slip.
Just wondering the best place to buy set of toothed pulleys,
Any reccomendations?
Rich
Justin14100
Quote from: XRrich on December 10, 2010, 12:13:29 PM
Rich
Try using belt dressing spray, it will help them grip a little - or try tensioning them again. are you using the right size belt? needs to be 8mm wide and not the usual 10mm.
Toothies, few german places do them - i made my own but they are steel and quite heavy. I'm trying to find a supplier to make some ali ones like the PSD set up was - so i might be able to get some in a few months depending on costs ect.
xrrich
I havent re newed the belts since the normal pulley was on, so ive oredered some from VW
Raw
I ran 65mm v belts for about a year and didn't have a problem with belt slip. fresh belts + belt dressing + plenty of tension = no problem. What lenth breaker bar are you using to tension the charger?
louisb1986
wheres the best place to buy a pully from been lookin about, want 65mm one, r they hard to fit
Raw
Quote from: louisb1986 on December 17, 2010, 10:42:17 PM
The hardest bit about fitting a pulley is changing the chip in the ECU. You can't justchange the pulley on it's own you need to change the ECU chip as well. You can buy pulley chip packages off german ebay or various tuning sites as listed in this post http://www.polog40.co.uk/forum/index.php/topic,5352.0.html
