Author Topic: Toothed Pulleys  (Read 3232 times)
Offline xrrich
Toothed Pulleys
« on: December 10, 2010, 12:13:29 pm »
Hi recently upgraded to a 65mm pulley and im getting alot of belt slip.
Just wondering the best place to buy set of toothed pulleys,
Any reccomendations?
Rich
Offline Justin14100
Re: Toothed Pulleys
« Reply #1 on: December 10, 2010, 12:30:56 pm »
Rich
Try using belt dressing spray, it will help them grip a little - or try tensioning them again. are you using the right size belt? needs to be 8mm wide and not the usual 10mm.
Toothies, few german places do them - i made my own but they are steel and quite heavy. I'm trying to find a supplier to make some ali ones like the PSD set up was - so i might be able to get some in a few months depending on costs ect.
Offline xrrich
Re: Toothed Pulleys
« Reply #2 on: December 12, 2010, 06:07:12 pm »
I havent re newed the belts since the normal pulley was on, so ive oredered some from VW
Offline Raw
  • It ain't dubbin 'less her thighs are rubbin'
Re: Toothed Pulleys
« Reply #3 on: December 14, 2010, 12:31:52 pm »
I ran 65mm v belts for about a year and didn't have a problem with belt slip. fresh belts + belt dressing + plenty of tension = no problem. What lenth breaker bar are you using to tension the charger?
Offline louisb1986
Re: Toothed Pulleys
« Reply #4 on: December 17, 2010, 10:42:17 pm »
wheres the best place to buy a pully from been lookin about, want 65mm one, r they hard to fit
Offline Raw
Re: Toothed Pulleys
« Reply #5 on: December 24, 2010, 12:14:59 pm »
The hardest bit about fitting a pulley is changing the chip in the ECU. You can't justchange the pulley on it's own you need to change the ECU chip as well. You can buy pulley chip packages off german ebay or various tuning sites as listed in this post http://www.polog40.co.uk/forum/index.php/topic,5352.0.html
