Author Topic: belt keeps coming off  (Read 4722 times)
Offline g40Ross
« on: December 02, 2010, 10:20:27 pm »
my belt keeps coming off! dont know why its as tight as it will go! pleasse help!
Ross
Offline scotsjohn
Re: belt keeps coming off
« Reply #1 on: December 02, 2010, 11:49:57 pm »
I'm assuming you've got a toothed belt set-up mate; if that's so then probable causes for it coming off are either the alternator or charger aren't sitting squarely. Loose rear mounting  on the charger is the first to check. The belt itself shouldn't be too tight; you should be able to twist it through 90 degrees on it's longest run by using finger and thumb.
Offline g40Ross
« Reply #2 on: December 03, 2010, 11:25:53 am »
as in the mount that holds it to the block?
Offline Jezza-7
« Reply #3 on: December 03, 2010, 02:14:21 pm »
Have you got the mount that goes onto the exhaust manifold?
Offline g40Ross
« Reply #4 on: December 03, 2010, 02:35:55 pm »
i have it but no on the car but it hasnt been an issue up untill about 3 weeks ago
Offline g40Ross
« Reply #5 on: December 03, 2010, 02:52:25 pm »
i have put the mount back on the exhaust and im just waiting on the battery to charge n whilst thats happening i best gett digging!
Offline Jezza-7
« Reply #6 on: December 03, 2010, 03:06:59 pm »
Yeah i run mine without that mount and its been fine, but strange for yours just to start slipping. Whats the wear like on the pulleys?
Offline g40Ross
« Reply #7 on: December 03, 2010, 03:33:19 pm »
they look alright to me!
« Reply #8 on: December 03, 2010, 03:50:53 pm »
not one of those ebay kits again is it?
Offline g40Ross
« Reply #9 on: December 03, 2010, 03:59:50 pm »
psd
« Reply #10 on: December 03, 2010, 04:50:58 pm »
hmm ok, shouldnt have problems with it if it is in good condition then.  I'd suggest something is out of alignment, exhaust mount shouldn't make a difference.
Offline g40Ross
« Reply #11 on: December 03, 2010, 04:53:31 pm »
how should i go about realigning them?
Offline scotsjohn
« Reply #12 on: December 03, 2010, 06:40:06 pm »
Strip off the belt and check the individual pulleys for tightness; particularly the alternator pulley. On my PSD kit, the alternator pulley had the wrong size keyway for the alternator shaft and eventually chewed it up with consequent belt wander. If all's well, you'll need a straight edge long enough to lay from the crankshaft pulley to the charger pulley. You can then use this to find if there's a pulley out of line.
Offline g40Ross
« Reply #13 on: December 04, 2010, 09:56:54 am »
if its the alternator pulley what do i do smash it with a hammer?
Offline scotsjohn
« Reply #14 on: December 04, 2010, 01:58:06 pm »
Smashing things under the bonnet with a hammer isn't really the way to treat your G40 mate. Either use your brain a bit; find a local G owner who can help; or sell the car to someone who'll give it some respect. Situations like this are a pain in the arse but when they're sorted properly you get more pleasure from your car and you've a bit more knowledge up your sleeve.
