Author Topic: G40 head - can have bent valves + other bits  (Read 2206 times)
Offline grungeisdead
« on: November 10, 2010, 12:48:10 am »
after a spare g40 head, i have a set of new sodium filled valves from a mate, so i dont mind if the spare head, has come from a car that had a cambelt failure, or melted piston, as long as the head isnt cracked, or excessivly warped.
cam not essential.
will also take any other bits - double valve springs etc.
also on my hunting list
- g40 engine bay loom
- g40 throttle body (std/dewedged or 51mm)
- g40 ecu
ta =]
Offline DKnight
Re: G40 head - can have bent valves + other bits
« Reply #1 on: November 10, 2010, 09:46:41 am »
we got a standard g40 throttlebody, wanting £40 for it
« Reply #2 on: November 10, 2010, 10:03:20 am »
g40 heads are the same casting as 1.3 if that helps
« Reply #3 on: November 10, 2010, 11:42:34 am »
cheers Pete, I've heard that, AFAIK its just the cam cover, double valve springs and sodium filled valves that differs? is that correct?
« Reply #4 on: November 10, 2010, 11:42:50 am »
will let you know squire
« Reply #5 on: November 10, 2010, 11:44:17 am »
yeah - but most gts and some cls have the double valve springs too.  the rocker gasket is different too - it has metal in the edges, not floppy rubber like others - and the cam cover bolts
« Reply #6 on: November 10, 2010, 01:18:04 pm »
Thanks dude for the info, you are a mini lil oracle aint ya  ;D :D
