Author Topic: Vw polo 6n G40 EATON.... ( Cage in )  (Read 6302 times)
Offline dani1326
« on: November 03, 2010, 04:34:03 pm »
hay all i picked up my new car sunday morning... its a 6n polo G40 running an eaton M45 charger fitted....
iv got a few plans for the motor :)
here she is
and here are the plans....
ENGINE;
toothed belt kit,
remap / ECU chip
camshaft
larger injectors
green samco hosing
moving the induction kit
green oil catch can :)
relocating the battery to the boot
BODY WORK;
deleting and hiding the bonnet washer jets
re-spraying the bonnet
fitting armored door plates ( sprayed candy white or the same green and the wheels )
INSIDE THE CAR;
fitting a half roll cage ( sprayed green to mach the wheels )
may be getting some GT3 seats??
fitting green 4point harnesses
and thats all the plans for naw :)
what do we think?
« Last Edit: November 14, 2010, 08:25:20 pm by dani1326 »
Offline jez1272gt
Re: Vw polo 6n G40 EATON....
« Reply #1 on: November 05, 2010, 09:46:16 am »
I like it and your plans sound ok...
ENGINE;
toothed belt kit, - eatons run on toothed belts
remap / ECU chip - good idea
camshaft - probably has an aftermarket cam in it, need to find out what or source a suitable one for remap.
larger injectors - may have some already. if not, probably a good idea for remap
Try and get as much info from the previous owner (or car builder) as possible... will make life much easier!
Good luck!
Offline dani1326
« Reply #2 on: November 06, 2010, 02:13:44 am »
ENGINE;
Good luck!
hmmm good plan ill send him a txt tomoz...i no for a fact its running a standard chip.....
my eaton charger has a normal pulley ( not toothed ) on is so the on it has must be a G40 pulley
ill take off the cam cover tomoz and look for at cam and same with injectors
Offline lance
« Reply #3 on: November 06, 2010, 12:23:54 pm »
eatons run a multi rib belt standard not toothed
Offline jez1272gt
« Reply #4 on: November 06, 2010, 10:47:26 pm »
My mistake of course the m45 doesnt run a tooth belt, half asleep there!!  ::)
Offline dani1326
« Reply #5 on: November 07, 2010, 01:15:00 am »
Lol you got me confused then :)
Offline dani1326
« Reply #6 on: November 14, 2010, 08:26:20 pm »
The cage is Naw I'n but to dark to take pics of tge finished article so I'll have them up tomoz :D
oki here are some pics :)
had to take out the front seats and what a pain that was :( lol
cage half in, i cut the rear seats to allow the cage to fit in snug :D
and here is the kinda finished article still need to hoover out the rear and fix in the rear supports.. but you get the idea
[/quote]
Offline dani1326
« Reply #7 on: November 15, 2010, 04:09:41 pm »
Offline Max
Re: Vw polo 6n G40 EATON.... ( Cage in )
« Reply #8 on: November 15, 2010, 05:06:57 pm »
Take the back seats out completely I reckon!
Offline Puncharado
« Reply #9 on: November 15, 2010, 07:34:53 pm »
Yeah, why bother with back seats?
The rozzers didn't like it when I had a white plate on the back of my mk2 Golf. I had to get the slip stamped at an MOT station after changing it and then produce this and my documents. So don't be surprised if you get pulled!
Offline dani1326
« Reply #10 on: November 16, 2010, 04:41:50 am »
Iv had the the plates on from the day after picking it up with no problems, iv always had pressed plates and they dont seam bothers round here.. Last time I was pulled they only said it was an MOT fail not illegal.... But that was before I had the white on...
Got the rear seats I'n cos IMO I'n my opinion it looks wank and the car I's louder without them so there staying
