Author Topic: mk1 golf conversion  (Read 17431 times)
Offline shaun_89
mk1 golf conversion
« on: October 25, 2010, 03:52:56 pm »
I have heard someone mention using mk1 golf driveshafts and i believe struts aswell on a mk3. I was wondering if this is true then would you then use mk1 golf cv's.
If this is all true would a ppp stage 3 subframe still fit?
thanks
Offline Etches
  • Still got the G...
Re: mk1 golf conversion
« Reply #1 on: October 25, 2010, 05:56:52 pm »
I know that mk1 struts have been used (modified to fit) and that the frames fitted with this. Don't strictly know about the mk1 driveshafts although i would presume they do as ive useddriveshafts from mk3 polos on mk2 and mk3 small block golfs.
Offline youngprodigys
  • G 3URO
« Reply #2 on: October 31, 2010, 02:18:52 pm »
MK1 coilovers on my mk3. used the larger mk1 golf cv joint (outer)
Offline hardchargin40
  • Older, Wiser, Greyer.
    • The Roadster.net
« Reply #3 on: October 31, 2010, 03:25:30 pm »
Nice one!
How did you work out the correct steering TCA bracket position height?  Side by side comparison?  Always wondered about it. ;D
« Reply #4 on: October 31, 2010, 04:46:08 pm »
Providing the setup you'll use fits the stock ARB/TCA then our frame will too.
Kriz- you got pics of the Mk1 Golf CV Joint next to a Mk3 one, out of interest?
Offline shaun_89
« Reply #5 on: November 01, 2010, 06:09:24 pm »
Are the mk1 coilovers a straight fit with everything lining up? Or was modification of the steering arms or tca's needed?
« Reply #6 on: November 01, 2010, 06:16:45 pm »
You have to weld polo steering arms to the struts.
Offline shaun_89
« Reply #7 on: November 01, 2010, 06:28:18 pm »
What do you mean? Is it done in the pic above?
« Reply #8 on: November 01, 2010, 06:36:42 pm »
Yeah that big black arm the track rod end ball joint bolts to doesn't exist on golf struts
Offline shaun_89
« Reply #9 on: November 01, 2010, 06:39:43 pm »
I get you know, so youd be able to postion it where you wanted to? Like when its lowered on the gaz coilovers?
  • G 3URO
« Reply #10 on: November 01, 2010, 07:40:07 pm »
yo!
i havent got a side by side comparison - but the original G40 outer cv joint went into the mk1 golf hub and had about 4-5mm of difference!!! it would spin round in the hub no problem without any of the teeth touching! so the mk1 golf gti hub is bigger on the spline dimension.
i worked out the height by lowering the car on the deck with no arms connected and set it how high i was going to run it - then marked it on the strut. - the ackerman angle i then copied by using the same angle you have on the standard shocks - and this works perfect:-) guy (mclovin on clubpolo) fooked this part up when he copied me and had the wrong angle so it steered like a pi$$ed up shopping trolley and had to come round mine to put it right.
there are 2 types of hub on the mk1 so make sure you get the "GTI" hubs as the lower spec ones have a different ball joints and wont fit!
i no longer have these as coilovers - there now air ride
il try and answer any questions as soon as i get time
KiZ
Offline Etches
« Reply #11 on: November 01, 2010, 08:13:25 pm »
What's people choices on coilovers to use with this modification? I presume its worth spending a fair amount on coilies but quite afew of you have chosen shocks n springs combos over this. What's your thoughts?
Offline newt
« Reply #12 on: November 01, 2010, 10:02:21 pm »
whats so good about mk1 golf legs?
no harm meant to people running them, just curious why you do it?
Offline Puncharado
« Reply #13 on: November 01, 2010, 10:39:20 pm »
For very low cars the seperate hub and strut allows for a little camber adjustment to get the wheels back to a decent angle.
Offline newt
« Reply #14 on: November 01, 2010, 10:55:31 pm »
ah ok
 i presume also that it enables to be run lower as mk1 shocks (inserts) are shorter than g40 ones
