Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Engine and Transmission
Timing / Air/fuel
« previous
next »
Pages: [
1
Go Down
Author
Topic: Timing / Air/fuel (Read 1968 times)
jimmyb1982
Timing / Air/fuel
on:
September 28, 2010, 08:17:57 pm »
Hey guys, the G40 is back. However I'm having trouble with the timing set up and fuel at high revs. If I set the timing correctly the car runs great about town but then leans out to Stoich at high revs where as if I retard the timing from the correctly timed position then it misses when driving slowly but keeps the air/fuel the right side of rich when on boost.
I spoke to Darren at G werks and he said get a fuel pressure gauge as it could be the fuel pump which I replaced in 2004 or the map I have but the map was fine with my old dizzy.
P.S. the dizzy was replaced in 2007 just before it came off the road. Cars been back on the road 6 weeks now.
Any ideas. I thought about getting a rolling road set up but the guy asked if theres a fuel mixture adjustment?
- Jimmy B
Administrators
Housewives heart throb
Re: Timing / Air/fuel
Reply #1 on:
September 28, 2010, 08:22:23 pm »
what chip do you have fitted?
and how do you know its lean? i.e. do you have a wideband fitted?
Traders
Reply #2 on:
September 28, 2010, 08:47:55 pm »
You saying it leans out to stoich on full throttle at high revs, or partial throttle?
If you haven't got a wideband you can't really tell what the fuelling's doing. And it's unusual for minor timing tweaks to make such a difference to the AFR - unless you're really swinging the dizzy around massively.
Are you setting the base ignition timing correctly? Is the dizzy the right part?
jimmyb1982
Reply #3 on:
September 28, 2010, 09:46:59 pm »
The chip is an SNS Green injectors PSD chip. No I'm not using a wideband, just a narrow band. I tried to time it on the top pulley because my toothed pulley has no notch or anything so I just tried with the top one but I'm not sure if thats right or not?
I've been told its a G40 part yes. What should the car idle at when warm? Is it about 950rpm?
- Jimmy
jimmyb1982
Reply #4 on:
September 28, 2010, 09:49:08 pm »
Sorry it leans out into stoich on full boost.
Administrators
Reply #5 on:
September 28, 2010, 10:00:10 pm »
should be 5+/- 1 degree advance on the top pulley.
what pullies are you using they should have a notch
jimmyb1982
Reply #6 on:
September 28, 2010, 10:15:25 pm »
I'm using the PSD toothies
jimmyb1982
Reply #7 on:
September 28, 2010, 10:16:27 pm »
how do I know if its 5+/-1 on the top pulley?
Administrators
Reply #8 on:
September 28, 2010, 10:30:41 pm »
you get a timing gauge where you can dial in advance.
If you are timing by the top pulley (not ideal in any case) with a static gun you'll be on tdc.
Administrators
The CV joint killer
Reply #9 on:
September 29, 2010, 09:29:06 am »
Quote
then you really have no idea what the fuelling is doing, a narrowband just isn't accurate, at all. Mine seems to show around 14:1 at high rpm/high boost but when remapping and we had the wideband connected it was really around 12:1 and 11:1.
jimmyb1982
Reply #10 on:
September 29, 2010, 07:31:11 pm »
should I get a rolling road set up do you think?
Traders
Reply #11 on:
September 29, 2010, 09:26:08 pm »
Get the ignition timing set properly to start with, then if it still runs badly take it to a rolling road that'll do you a power run with AFR plot. Speaking of which, John Sleath would do that for you at the G40 RR day in a few weeks...
Pages: [
1
Go Up
« previous
next »
Club G40 Forum
Technical
Timing / Air/fuel
