How much for a 1.5 conversion??
Started by Richg40, August 09, 2010, 09:47:49 PM
Richg40
Lets say you knew someone selling a 1.5 bottom end, G40 block, brand new 1W crank, brand new custom accralite pisons with new main and big end bearings.....
how much would be reasonable to pay?
Between £1k-1.5k maybe that's just my geustimate though!!
Richg40
For just the bottom end? Seems a bit much?
Henry
I was under the impression that brand new cranks are £250-300, pistons are £500-550 brand new, g40 block is worth something like £50 and however much the bearings are worth minus a percentage for second hand value and that gives you a rough price.
Yea think henrys estimate mite be a bit more accurate than mine !!
Richg40
£750 about reasonable then I guess.
£750 would be a bloody bargain, don't forget at least £100 block machining, £100 set of bearings...
Also depends which block has been used, and who's done the work.
depends on whether cranks been balanced too - and if relief work/boring been done and by who
Richg40
It's a G40 block, built by a BMW senior tech and the boring was done by the machine shop they use to a very high standard.
offer £750 and see what happens.  Is it a guy called Gregg who is selling it?
Richg40
oh OK.  It's just I know of a lad who used to be into g40s who (I think) is a senior bmw tech, just wondered if it was the same guy.  No idea if he ever built a 1.5 bottom end though.
lance
new oil pump with it as that'd be another 100plus for that. it would cost you over a grand to do
Richg40
No oil pump, but it shouldn't be a problem to get one at trade genuine i guess.
