Author Topic: 085 Gearbox shift mechanism removal...  (Read 1444 times)
Offline Keppel
« on: June 15, 2010, 08:33:12 pm »
i'm in the middle of an 085 gearbox stripdown and rebuild.
I have the box split, but I cant get the inpuyt and output shafts out of the casing because the shif mechanism is in the way.
I don't know how to remove it, The shaft that the mechanism is mounted to looks like it is threaded or pressed into the casing, there is a female m7 thread in the end of the shaft visible from the outside of the casing.
is there a special extraction tool, or will a slide hammer work to remove it, or do i need to lock a nut and bolt against is and unscrew it.
any advice would be much appreciated.
Re: 085 Gearbox shift mechanism removal...
« Reply #1 on: June 15, 2010, 08:43:48 pm »
yeah there's an aluminium dowel pressed into the casing which holds the bar in the middle of the shift mechanism.  It has a tapped hole in it so you can screw a screw in and use a slide hammer.
Offline Keppel
« Reply #2 on: June 15, 2010, 08:45:36 pm »
awesome,
Thankyou indeed!
