Not totally sure what's at fault here, but I seem to have an intermittent missfire under load. The car bogs down and splutters.
But it is intermittent.
The first time it happened was back in February, I hadn't used the car much due to the snow. It was down to the dregs in the tank, so I the first place I drove it was down to the BP garage down the road and it was spluttering then.
Then I had a poor month in April, decided to leave the car in the garage for a few weeks as it's a bit thirsty. Got it out at the beginning of May, again with dregs in the tank, drove it to the garage and filled up. No drama. Drove it to work the next day and for the first two or three miles it was spluttering. Then it seemed to clear and it was fine (actually, it was bloody brilliant) for a month.
Being a bit of a nob, and very busy at work, I ran it down to fumes last Friday. It was fine, but there's no Shell garage near me so I wanted to fill up after work (there's one near the office). As I drove away from the office it was spluttering a bit, then on the way back to mine it was doing it really badly. Really smooth while cruising, but bogging down with no power when on boost. Which to my mind suggests a fueling issue?
Well to add complication to it, someone who moved my car at Mod Nats the weekend before had said my clutch needed adjusting so I thought I'd have a fiddle on Friday before driving to get fuel.
On Sunday I changed the fuel filter, assuming it was clogged.
Just been out for a spin and again, first few minutes it was spluttering quite badly. Idling beautifully though! So I stopped, wound the clutch back to where it was, roughly, and it seemed to be better afterwards. Actually, it seems fine.
So I'm wondering, is this an issue with fueling? And could it be as simple as having a load of shit at the bottom of my tank?
Or is it something more sinister, like a faulty component. I know it's not the lambda, as it didn't have one between October and mid April and the first couple of spluttering moments it was running without a lambda. Now it's got one, and it's doing the same.
Or could having a clutch not biting properly cause it to splutter a bit under load?
