Porting
Started by Jezza-7, March 26, 2010, 06:10:17 PM
Is this had a lot of porting done to outlet of lader?
bushyg40
ye quite a bit but not the maximum
Ok, its a psd full blend charger. I thought that was quite alot that had been done.
it is quite a lot yeah... seen a bit more severe but yeah - looks like a normal full blend to me
awesome cheers pete!!
Is that the one I sold you James ? If it is it was definantly full blended then serviced by jabba if I remember correctly
Yeah antony it is. Nothing against you as i beleive you. I was just wondering as someone posted there lader up a little while ago and said theres was a full blend but it looked standard. I mean if that was then what was mine.
Get some pics of yours up too, has it had more than a full blend?
bare in mind that these chargers are ported by hand, not done on a CNC.  So each one will be slightly different and what is called a "full blend" will change a fair bit over the amount of years steve/PSD was doing them.  So pics of one that was ported in 2001 will look a bit different to pics of one done in 2008.
Daryl
Ive got one that was ported around 2004 by darren. Will pop a picture up.
in my opinion most full blends have the outlet ported too wide- wider than the outlet dome, which doesn't make much sense - and equals poor flow
Nick_S
My full blend came with a ported outlet elbow though.....if thats what you are meaning Pete?
Yeah mine did too. In comparison mine is the same diameter.
Quote from: Nick_S on March 28, 2010, 11:15:37 PM
yeah - but if you lookfrom the inside out - most full blends are bigger than the ported outlet - you'd have to port it past the o ring to get it port matched.
Nick_S
Surely then it aint gonna seal air tight properly, if you can see the o-ring when bolted onto an exhaust casing?
true - but ever ran one without an o ring?  you dont really notice a lack in boost lol - depends how well the mating surfaces go together
