Cam info
Started by Jezza-7, March 23, 2010, 05:07:48 PM
When fitting a new cam, is there anything that you should replace or is worth replacing?
I have got the ina hydraulic cam followers from GSF.
Puncharado
Camshaft oil seal (030 103 085A) and maybe dizzy o-ring seals (Large 030 905 224 & small 030 905 261).
Cheers. Are Cam followers are also known as lifters?
Would you recomend replacing springs?
breadman
Quote from: Jezza-7 on March 23, 2010, 08:49:04 PM
Yeah the same thing in this case.
I think the general concensus is that the springs don't need replacing unless the engine has covered massive mileage.
Just looking at schrick cams at the mo and could someone tell me what the standard inlet/outlet is compared to a cam with 252/276.
What gains do you get?
