Milage Clocks stopped working
Started by xrrich, February 23, 2010, 09:26:02 AM
xrrich
hi just wondering the possible things it could be that is causing the clocks not to work.
XRrich
cheys03
Broken clocks, broken cable from gearbox to clocks.
Does the speedo work?
xrrich
cheys03
I would think it's the clocks that are broken then.
grayg40
thats one way to keep the milage down.
DKnight
Fred
Probably the coil spring that it fights against.
xrrich
Can i buy any clocks from any model. or do they have to ben g40 ones?
Also is there a brief hint guide of how to change them?
Rich
jez1272gt
G40 clocks are specific as the speedo goes round to 160mph rather than the non-g4o ones which are less. The gt and G40 clocks both have a tachometer though and if im not mistaken you could use GT ones if you wish. however some might correct me on this!!?
