Good news Ben- bagged a good 'un.
To add on what I've already said, this backpressure argument with a larger bore system is b0llcks to be honest. The drop in torque Phil/Nick are experiencing is due to the A/F ratio changing due to a larger flow of air. If you consider 'boost' as back pressure instead of manifold pressure- you've both fitted a larger bore exhaust system- Nick has mentioned a drop in boost pressure- ergo an increase in flow through the engine.
Unfortunately the poor old Digifant ECU can only work with what the MAP sensor tells it, so even though you're flowing more air, have a lower manifold pressure reading, you actually need more fuel. Torque curves can be massively affected by A/F ratio- my Clio for example 'comes on cam' at 5,000rpm.... does it bollocks! It's a marketing thing which Renault did to give you a kick in the back once they actually add some fuel in above 5k.
To conclude, you won't loose any torque by fitting a 63mm system or a decent 4 branch, providing your car is mapped properly afterwards. I know neither of the above cases have been, so a comparison between the two is unfair.
Nick- I'd check your cam timing too, you should see positive boost pressure well before 4500rpm.
