One thing i noticed and worthwhile bearing in mind if you are staying with the G40 blower; don't go bigger bore than 2.25" on an exhaust system.
I've recently installed one of the PPP systems which is 2.5" at the downpipe exit. Having stepped up directly from a 1.75" system, i have lost 1 psi of boost. Mine already has a very well flowed BVH cylinder head which was giving 9psi boost on the OE bore with a 4 branch, now gives 8psi with the PPP system (65mm toothed pulleys). Car certainly feels more laggy low down now than it did. I could fit a bigger blower of course to get max output, but i'll try tweaking a few things before i go down that route.
