timing
Started by matthg40, December 12, 2009, 10:39:58 PM
matthg40
evening all im having trouble with my timing the camshaft and crankshaft pullys are inline with the marks to set it up.now im having trouble with the distrubitor i cant seem to get it in the correct position for it to run perfect.ive had a strobe light on it to set it but no joy any advice would be appriciated many thanks matt ::) ;D ;D 8)
hardchargin40
Did you set it to the correct mark?  the O or the Z.
matthg40
i was told to set it to the z
hardchargin40
Set Cam to the 0 mark.
Set 6deg ignition timing to the Z
matthg40
i set the crank to the z and just lined the cam up with the arrow on the cam cover
thats why it runs like shit then! probably a tooth out.
the cam timing is probably a tooth or so out then.
matthg40
so in simple leicester speaking terms lol thats none technical what do i need to set it to
matthg40
sorry boys im lost lol i need to set the cam to the o and the ignition to z correct?so what about the crank
hardchargin40
Do a search on cam timing.  You are aligning the camshaft pulley dot against the arrow with the bottom crank pulley's O mark.
Once this is done, you can use a strobe light to set up the ignition base timing.  by moving the distributor round to align the Z mark (engine running).
matthg40
the z mark on the crank pully is that correct
matthg40
im sorry to sound a dumb ass my haynes manual is about as useful as a chocolate kettle
matthg40
so what am i setting the crank to sorry mate ive got man flu which is slowing my brain down
matthg40
cheers mate sorry to be a pain ive had such a game with it all thanks all for your help ;D
