Author Topic: i don't now wath to do anymore!  (Read 4934 times)
Offline Alvaro
« on: November 24, 2009, 07:21:22 pm »
I, i have a problem in my G,
when i run it at low speed(no more than 3000 rpm) it seems to run normaly,
but,  after i step on it(uper rpm\positive air pressure on inlet), when i take my foot of, and stabilised at low speed, it runs like jumping, like cuting of the engine and starts again.
this happens allways just after full trotle.
I already done the diagnostic test, and the computer says that the ecu don't recognises(no signal)
the co sensor and the blue temp. sensor.
i put new sensors and the ecu still don't recognises.
Wath it could be? Any ideas?
thanks
« Last Edit: November 25, 2009, 07:54:22 pm by hayesey »
Re: i don't now wath to do anymore!
« Reply #1 on: November 24, 2009, 07:49:01 pm »
an ecu fault?
Offline Alvaro
« Reply #2 on: November 24, 2009, 11:41:36 pm »
i already tested another ecu, and still the same problem.
« Reply #3 on: November 25, 2009, 08:11:16 am »
sounds like the wiring is the problem then
Offline Alvaro
« Reply #4 on: November 25, 2009, 04:10:13 pm »
thanks for your replys,
any idea about how can i test the wires?
Offline AllinOne
« Reply #5 on: November 30, 2009, 12:27:06 am »
Im havin the same problem, but mines overfueling. Need to chech that blue sensor wen i get some spare cash :$
Offline TDK
« Reply #6 on: December 02, 2009, 08:22:22 pm »
just out of curiosity - how much does a blue sensor cost ? (anyone???)
I'm looking a Danish site called refako.dk (http://www.refako.dk/index.php?cPath=1_100000121_245000427_110000440_120001953&tPath=55)
and the blue censor cost dkr 240,- which is roughly around £24 GBP (not counting postage and pacageing)
Offline Alvaro
« Reply #7 on: December 02, 2009, 11:39:51 pm »
well, here, in portugal, at vw, costs around 25 euros.
Offline Alvaro
« Reply #8 on: December 02, 2009, 11:52:20 pm »
and about testing the wiring? i need some ideas. ??? :-\
Offline dannyb.G40
« Reply #9 on: December 04, 2009, 10:02:07 am »
you could start by using a multimeter to test the continuity of the wiring, its tedious but the only way.
If they are all okay then i suppose you'd have to try and find a wiring diagram and check they are correctly wired up.
Offline AllinOne
« Reply #10 on: December 08, 2009, 02:24:38 pm »
My mate got a gsf one for his gti for about a tenner i think? If thats the same part at all?
Offline ctothey
« Reply #11 on: December 16, 2009, 08:12:36 pm »
Have you had it apart? stripped things recently? i've had a simliar scenario,
turns out the knock sensor and the co pot multiplugs, fit each other!
if you have had it apart, definitely check there on the right way round.
hope this helps.
cy
Offline Alvaro
« Reply #12 on: December 30, 2009, 06:32:10 pm »
weel, after all, the problem was switched plugs. Problem solved,hehe.
thanks for the replys, worth a lot to me...
