i don't now wath to do anymore!
Started by Alvaro, November 24, 2009, 07:21:22 PM
Alvaro
I, i have a problem in my G,
when i run it at low speed(no more than 3000 rpm) it seems to run normaly,
but,  after i step on it(uper rpm\positive air pressure on inlet), when i take my foot of, and stabilised at low speed, it runs like jumping, like cuting of the engine and starts again.
this happens allways just after full trotle.
I already done the diagnostic test, and the computer says that the ecu don't recognises(no signal)
the co sensor and the blue temp. sensor.
i put new sensors and the ecu still don't recognises.
Wath it could be? Any ideas?
thanks
Alvaro
i already tested another ecu, and still the same problem.
sounds like the wiring is the problem then
Alvaro
thanks for your replys,
any idea about how can i test the wires?
AllinOne
Im havin the same problem, but mines overfueling. Need to chech that blue sensor wen i get some spare cash :$
TDK
just out of curiosity - how much does a blue sensor cost ? (anyone???)
I'm looking a Danish site called refako.dk (http://www.refako.dk/index.php?cPath=1_100000121_245000427_110000440_120001953&tPath=55)
and the blue censor cost dkr 240,- which is roughly around £24 GBP (not counting postage and pacageing)
Alvaro
well, here, in portugal, at vw, costs around 25 euros.
Alvaro
and about testing the wiring? i need some ideas. ??? :-\
dannyb.G40
you could start by using a multimeter to test the continuity of the wiring, its tedious but the only way.
If they are all okay then i suppose you'd have to try and find a wiring diagram and check they are correctly wired up.
AllinOne
My mate got a gsf one for his gti for about a tenner i think? If thats the same part at all?
ctothey
Have you had it apart? stripped things recently? i've had a simliar scenario,
turns out the knock sensor and the co pot multiplugs, fit each other!
if you have had it apart, definitely check there on the right way round.
hope this helps.
cy
Alvaro
weel, after all, the problem was switched plugs. Problem solved,hehe.
thanks for the replys, worth a lot to me...
