supercharger
Started by dazzle53, November 14, 2009, 09:13:03 PM
dazzle53
how long do i need to run in a rebuilt charger for?
thanks
darren
LeonL
Recomened distance is 400miles
dazzle53
Justin14100
what would happen if you just ragged it as soon as it was built?
LeonL
Think it blows the seals
Justin14100
ah, well i had a broken lambda and had to use boost as it was over fuelling big time on the motorway. spose a rebuild will be soon coming again then!
Justin14100
Quote from: Rae on November 15, 2009, 07:59:51 PM
Quote from: Justin14100 on November 15, 2009, 12:57:34 PM
"had to" ?? rich is better than lean....
Yeah, that does make me sound like a tool i know.
It was OVER over fuelling. as in, black smoke out the back all the time, and it was SO rich. it had to be on boost to get the air in there to burn it. or it decelerated. did it for months. 17mpg too. that 170 miles from a tank. so yes. I 'had to' (unfortunately)
I just hope you haven't bore washed the engine as I did that in very similar circumstances (or at least that's what I suspect happened, the next time I used the engine it was down on compression, I've since replaced it).  Really if it's overfuelling to that extent then it's time to call the AA/RAC/whoever you're with.
Justin14100
Quote from: hayesey on November 15, 2009, 08:54:08 PM
Will do next time. Thanks for the advice.
I did put up with it, fixed it now though!
derbik
Hi
I got this supercharge for sale £150 + Delivery
I'm not to schure about condition of this so im selling it as broken.
Because its not my ,
Heare some fotos:
http://www.aukcjoner.pl/gallery/001692124-.html#I1
