Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Engine and Transmission
Cylinder head
« previous
next »
Pages: [
1
Go Down
Author
Topic: Cylinder head (Read 4268 times)
Alexiskayak_7
Cylinder head
on:
June 13, 2008, 11:13:27 pm »
Well , does an engine from a vw golf 3, 8valve with ABT engine code 1350cc (monopoint injection), has the same cylinder head with PY (G40) ones???
Generally, is there something same wit the G40s???
Administrators
The CV joint killer
Re: Cylinder head
Reply #1 on:
June 15, 2008, 03:55:20 pm »
I don't know about golf heads but all 1272cc mk3 polos have the same head. G40s have different exhaust valves and cam but the actual head itself is the same.
Alexiskayak_7
Re: Re: Cylinder head
Reply #2 on:
June 16, 2008, 01:29:48 am »
[quote pid=1764 author=hayesey date=1213541720]I don't know about golf heads but all 1272cc mk3 polos have the same head. G40s have different exhaust valves and cam but the actual head itself is the same.[/quote]
Yes, with the first sight you can see that they are similar, but in the inside???
Administrators
The CV joint killer
Re: Re: Re: Cylinder head
Reply #3 on:
June 16, 2008, 01:08:42 pm »
yes, all the 1272cc polo heads are the same casting. just different cam and exhaust valves on G40s (they have sodium filled ones to keep temps down).
grayg40
Re: Re: Re: Re: Cylinder head
Reply #4 on:
July 15, 2008, 12:25:33 pm »
The G head has the oil port for the feed charger
Administrators
The CV joint killer
Re: Re: Re: Re: Re: Cylinder head
Reply #5 on:
July 15, 2008, 04:15:45 pm »
no it doesn't it just has a t-piece fitted where one of the pressure sensors go in. The head casting is the same part as any 1272cc mk3 polo.
Last Edit: July 15, 2008, 04:16:06 pm by hayesey
Alexiskayak_7
Re: Re: Re: Re: Re: Re: Cylinder head
Reply #6 on:
July 15, 2008, 04:37:15 pm »
I can see that they look the same, but it's from a VW with ABT engine code and it has 1350cc....
Pages: [
1
Go Up
« previous
next »
Club G40 Forum
Technical
Cylinder head
