Author Topic: eaton m45  (Read 4133 times)
Offline VW_rae
eaton m45
« on: August 22, 2009, 01:34:12 pm »
hi guys and girls i was just goin threw my garage and i stumbled on a eaton m45 i have had it for a while and was just wondering is it worth putting it on a g40???is it a difficult conversion??h???and how much did it set you back?? and was it worth it in the end??thanks guys
Offline vwmk3jon
Re: eaton m45
« Reply #1 on: August 22, 2009, 07:30:11 pm »
The hardest parts are fitting the charger so its secure (AW kits had this problem) and getting a suitable map to run the mods.
189bhp been made from a G40 running a standard bottom end with other mods so theres room for big power increases without the rebuild every 20k or so.
Offline VW_rae
Re: eaton m45
« Reply #2 on: August 26, 2009, 06:37:36 pm »
cheers matey erm it may sound ditsy but would you have an idea as to were i can get one of these kits or something that would hold it in place better?
Offline vwmk3jon
Re: eaton m45
« Reply #3 on: August 27, 2009, 06:26:27 pm »
Im sure the PSD kits used a modified G-lader mount. I can get you some pics of my set-up if you want?
Offline VW_rae
Re: eaton m45
« Reply #4 on: August 28, 2009, 12:08:56 am »
would you please mate thank you so much.cheers
Offline vwmk3jon
Re: eaton m45
« Reply #5 on: August 28, 2009, 03:57:14 pm »
Ill try and get you some when I get home if it's not hammering it down.
Offline GR40
Re: eaton m45
« Reply #6 on: September 29, 2009, 10:15:59 am »
I made the conversion to an Eaton M45! Basically cause replacing my broken G-lader charger, where I live, would cost me €1800 or more! I spent €700 instead, in total, for a used eaton m45, custom mountings, air filter. a 5pk belt, pulleys and tensioner, pipes and silicon hoses to fit the charger to the original intercooler! No remap was made and it runs fine for the last 2 years! I show an extra 15hp and 2kgm of torque on the rolling road!
Here are some photos of the "making of"! Since then i found out i made some mistakes! like the return hose or the really big tensioner!
